jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,334 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
When I let out the clutch pedal, it makes a "creaky" noise are it comes up and a feeling. Some friction accompanies the clutch return.
First noticed this when I couldn't easily start off in1st. IIRC, the pedal cluster is less than 10 years old. Where should I start ? |
jim_hoyland |
Turned out to be a loose clutch tube. My Indy repaired the tube by using rear-trunk torsion rod clamps. Also replaced the clutch cable; it had a couple of broken strands near the pulley.
Lo-Fi Version | Time is now: 25th June 2024 - 10:12 PM |
