buck toenges |
Senior Member ![]() ![]() ![]() Group: Members Posts: 553 Joined: 25-November 03 From: Fort wayne In Member No.: 1,388 Region Association: None ![]() ![]() |
I have 2 914s. The green one is a 71 with 195/50 R15 tires and the other has 225/50 R16 tires. I have been reading up on ride height and rake. I am curious to what you guys think about my ride height.
I am measuring at the top valance lip were they connect to the metal of the body. I measure behind the front tire well and in the front of the rear tire well. The green car has the front height at 10 1/4" and rear of 10 3/4". Again the tire size is 195/50 R15. The blue car front height is 11 1/8" and rear is 12 1/4". The tires are 225/50 R16 rear and 205/50 R16 front. The blue car has a 1988 911 front suspension and a 3.2 engine. Blue car also has a front oil cooler that fits through the front bumper. I am looking for ride heights for both cars. Should the blue car have similar height and rake as green car? Or should it be taller since the tires are probably taller than the green car? ![]() |
Freezin 914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 882 Joined: 27-July 14 From: Wisconsin Member No.: 17,687 Region Association: Upper MidWest ![]() ![]() |
I am no expert, but generally when you change diameter of a wheel, you usually change sidewall profile to compensate for tire diameter changes.
I know overall it is a ratio between the sizes, but between the two tires you listed, are they the same diameter? Since they are both 50 series, but you have a difference of an inch between the wheel size. That alone may account for the difference in ride height. At a glance, I would prefer the stance of your green car. But everybody has different tastes. Both of your cars look great btw. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 26th June 2024 - 06:29 AM |
