buck toenges |
Senior Member ![]() ![]() ![]() Group: Members Posts: 553 Joined: 25-November 03 From: Fort wayne In Member No.: 1,388 Region Association: None ![]() ![]() |
I have 2 914s. The green one is a 71 with 195/50 R15 tires and the other has 225/50 R16 tires. I have been reading up on ride height and rake. I am curious to what you guys think about my ride height.
I am measuring at the top valance lip were they connect to the metal of the body. I measure behind the front tire well and in the front of the rear tire well. The green car has the front height at 10 1/4" and rear of 10 3/4". Again the tire size is 195/50 R15. The blue car front height is 11 1/8" and rear is 12 1/4". The tires are 225/50 R16 rear and 205/50 R16 front. The blue car has a 1988 911 front suspension and a 3.2 engine. Blue car also has a front oil cooler that fits through the front bumper. I am looking for ride heights for both cars. Should the blue car have similar height and rake as green car? Or should it be taller since the tires are probably taller than the green car? ![]() |
wonkipop |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,440 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille ![]() ![]() |
not sure where you are measuring your ride ht to on the car?
i have a 74 1.7 set up dead level. running orig correct profile/size 165 tyres. i measure exactly 200mm either end of sill panel - to that little fold down lip between bottom of outer sill panels and floor pan/longs. 200mm = 7.87 inches. it used to be "up at front" in that crazy stock way. natural understeer vw engineer caution? i like it dead level. feels real sweet. 914/6s look like they were set up dead level stock? but just going off old pictures. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 26th June 2024 - 06:20 AM |
