Craigers17 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 760 Joined: 5-August 17 From: Rome, GA Member No.: 21,317 Region Association: South East States ![]() ![]() |
I am looking for some advice on carburetor setup. I know there are 100's of threads on this, but I am looking specifically for advice on setup for IDF 40's. I've read where putting phenolic spacers in place limit the possibility of boiling the gas.
So my first question is what is the basic setup? Are we talking about a Victor Reinz type of gray/black gasket between the head and the manifold intake. Then a 1/4 or 1/2" phenolic spacer between the intake and the carburetor? Also, is there a paper/cork gasket that has to go on either side of the phenolic spacer? I plan on replacing the hex bar with either the CSP linkage or, more than likely, Chris's pulley setup, but I want to make sure the setup between the carbs and manifolds is ideal before I start tinkering with the air flow and syncing them. Any feedback would be great. Here is a pic of the spacers that I'm looking at: ![]() |
mb911 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,970 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest ![]() ![]() |
On a 911 based engine it goes gaskets, phenolic, gasket, intake, gasket, carb.
Is that what you were looking for? |
Craigers17 |
On a 911 based engine it goes gaskets, phenolic, gasket, intake, gasket, carb. Is that what you were looking for? @mb911 Yes thanks! However, when I was researching this topic, I also found the following pic. Is this unnecessary, overkill, or just dependent on engine size/configuration? Notice the spacers between the carbs and intakes. ![]() |
Lo-Fi Version | Time is now: 26th June 2024 - 02:40 PM |
