Sheared off bolt head, Front axle |
vitamin914 |
May 2 2022, 11:13 AM
Member Group: Members Posts: 202 Joined: 8-September 21 From: Toronto Canada Member No.: 25,893 Region Association: Canada |
While reading the thread about 4" hole under the gas tank and the protective cover for the steering rack I decided to get under mine to see if I need the protective cover. Yes, I do, and I found something I did not expect a sheared-off bolt head. (IMG:style_emoticons/default/unsure.gif)
See photos. Right side ok, left side not so good. No clue what caused it was but it is painted over and not fresh - (IMG:style_emoticons/default/mad.gif) must have existed when I bought the car. I know this is not correct and needs to be fixed. I don't know what these supports are holding but I suspect it is the front axle. Is it dangerous? How urgent should it be? Anyone have a feel for the difficulty in removing that sheared bolt? |
Front yard mechanic |
May 2 2022, 12:55 PM
Senior Member Group: Members Posts: 1,176 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None |
Soak that with pb blaster. Pull the bar down and put a vice grip on it that will come loose easy peasy
Bartlett 914 |
May 2 2022, 01:04 PM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
Soak that with pb blaster. Pull the bar down and put a vice grip on it that will come loose easy peasy That was my first thought. The steering rack can be lowered enough to allow vice grips. Really give the PB Blaster time to work. Heat will also help. Don't get greedy when removing. Allow a little back and forth motion when working it out |
Lo-Fi Version | Time is now: 26th June 2024 - 12:02 AM |
