vitamin914 |
Member ![]() ![]() Group: Members Posts: 202 Joined: 8-September 21 From: Toronto Canada Member No.: 25,893 Region Association: Canada ![]() ![]() |
While reading the thread about 4" hole under the gas tank and the protective cover for the steering rack I decided to get under mine to see if I need the protective cover. Yes, I do, and I found something I did not expect a sheared-off bolt head. (IMG:style_emoticons/default/unsure.gif)
See photos. Right side ok, left side not so good. No clue what caused it was but it is painted over and not fresh - (IMG:style_emoticons/default/mad.gif) must have existed when I bought the car. I know this is not correct and needs to be fixed. I don't know what these supports are holding but I suspect it is the front axle. Is it dangerous? How urgent should it be? Anyone have a feel for the difficulty in removing that sheared bolt? ![]() ![]() |
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,579 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
You may not want to remove the crossmember but your best shot is with all interference removed. Drill a 1/4" hole in the stamped metal mount above the stuck bolt and flood the interior of the mount with your favorite penetrant. I think that can be done without romoving thr tank. Vise grips allow back-and-forth motion....pipe wrenches don't. |
Lo-Fi Version | Time is now: 25th June 2024 - 11:58 PM |
