bandjoey |
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,929 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region ![]() |
3000 miles back and January 2020 I did the usual brake job. Normal Textar pads. Rotors measure good and solid bleeding and PMB seating method. After that I had great brakes all the way up to now. With no warning pedal goes about 50% travel to the floor but still had weak braking. Found the reservoir empty to the bottom of the container. No sign of leaking fluid on the car, wheels, or garage floor. Filled it up and a short test drive brakes are back to normal. No loss of fluid.
Where did all the fluid go? If the master cylinder or a caliper started leaking wouldn’t there be evidence of fluid on the ground ? |
bandjoey |
Ah aha. I always thought the fluid would just runoff the master cylinder to the ground.
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,643 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
Ah aha. I always thought the fluid would just runoff the master cylinder to the ground. unfortunately no... it needs to melt off all of your floorboard paint and pedal cluster paint before it gets to the ground. ps. if you still have stock nylon bushings in the pedal cluster they often swell and get destroyed too. if you have upgraded brass bushings then they can be reused. brant |
Lo-Fi Version | Time is now: 26th June 2024 - 12:06 AM |
