Fuel injection issues? Possibly run carbs? |
bmtrnavsky |
Apr 19 2022, 01:52 PM
Member Group: Members Posts: 355 Joined: 20-October 07 From: Longview, TX Member No.: 8,245 Region Association: Southwest Region |
My 914 has been sidelined since 2012 for a number of reasons but was parked not running. Pulled it out of mothballs and hauled it over to the local vintage Porsche mechanic who said my impulse sender had no signal. He said he was unable to source parts for it and was unsure if replacing that part would get it back on the road his recommendation was to convert to Weber 40's. I'm not rich so I understand his hesitancy to open what could be a very expensive can of worms.
So here is where my questions start I'm just looking for a solid running reliable car that I can drive on trips and maybe autocross 2-3x per year. anyone have a source on the impulse senders? can they be rebuilt? Is the Carb it advice good? I have a basically stock 2.0 with hydraulic lifters and a very mild cam. Will I have to change my cam to convert it? what's the best carb? I have seen 34's 40's and 44's people seem to do all three are there pros and cons to each setup? Can I get this conversion done for around $1500 in parts and is it a achievable project for an average mechanic? I suck with electrical but I have plenty of tools and am not afraid to learn as I go. I have done head gaskets and other mid level projects before. |
r_towle |
Apr 30 2022, 05:02 PM
Custom Member Group: Members Posts: 24,624 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
123 works to replace trigger points?
How? |
BeatNavy |
Apr 30 2022, 06:04 PM
Certified Professional Scapegoat Group: Members Posts: 2,933 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
nivekdodge |
Apr 30 2022, 09:32 PM
Member Group: Members Posts: 263 Joined: 28-August 21 From: Pittsburgh Pa Member No.: 25,860 Region Association: MidAtlantic Region |
123 works to replace trigger points? How? Yes, the D-Jet version of 123 provides the functionality served by stock trigger points. Works like a champ. I have one of these for my 1.8. Can I buy and run a djet system on my 1.8? |
ClayPerrine |
Apr 30 2022, 09:54 PM
Life's been good to me so far..... Group: Admin Posts: 15,820 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
123 works to replace trigger points? How? Yes, the D-Jet version of 123 provides the functionality served by stock trigger points. Works like a champ. I have one of these for my 1.8. Can I buy and run a djet system on my 1.8? You don't need trigger points on a 1.8. L-Jet doesn't use them. Just get the proper distributor for a 1.8 and plug it in. Clay |
nivekdodge |
May 16 2022, 04:31 PM
123 works to replace trigger points? How? Yes, the D-Jet version of 123 provides the functionality served by stock trigger points. Works like a champ. I have one of these for my 1.8. Can I buy and run a djet system on my 1.8? You don't need trigger points on a 1.8. L-Jet doesn't use them. Just get the proper distributor for a 1.8 and plug it in. Clay Clay I have the single carb on the engine. Snce I have the distributor , can I buy the djet setup and use it? |
Lo-Fi Version | Time is now: 28th September 2024 - 04:17 PM |
