Series9 |
Lesbians taste like chicken. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,444 Joined: 22-August 04 From: DeLand, FL Member No.: 2,602 Region Association: South East States ![]() |
By request, I'm posting the few pictures I have of the installation of my steel flares.
I started by taping them to the car to find the correct position. It's a subjective placement and I recommend NOT using FG GT rockers as a guide. Mine would have been wrong if I had. Instead, I found that the arch of the flares was slightly larger than the arch of the factory fender. I taped them on in a position that split the difference when you looked at the car from the side. Attached image(s) ![]() |
Phoenix-MN |
Senior Member ![]() ![]() ![]() Group: Members Posts: 927 Joined: 23-January 04 From: ST. Bonifacius,MN Member No.: 1,590 ![]() |
I found that you can get a accurate cut line if you cut and weld as you go around the flare (just another method) I agree with 914RS on the FG rockers, I had several different one and no two were alike. I ended up using measurements that were from a true 916 to locate the flares and then used the rockers that best match the positions.
My method http://www.phoenixhobbies.com/html/flares.html |
Lo-Fi Version | Time is now: 27th June 2024 - 08:32 PM |
