Geezer914 |
Geezer914 ![]() ![]() ![]() Group: Members Posts: 1,474 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States ![]() ![]() |
If I install a Mallory distributor in the stock location, with #1 at 11:00, the clips that hold the distributor cap interfere with the engine tin, making setting timing difficult. Just want to double check myself, if I rotate the distributor drive gear to one or two teeth so it lines up with 9:00 with the engine at top dead center, I can line up the rotor at 9:00 and be at top dead center for #1?
VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,475 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() |
Can you find Mallory dizzys again? They were NLA for years.
And, yes. You have to dimple the tin to make a Mallory work well. Zach |
Jack Standz |
Member ![]() ![]() Group: Members Posts: 295 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None ![]() |
Can you find Mallory dizzys again? They were NLA for years. And, yes. You have to dimple the tin to make a Mallory work well. Zach Yes, you are correct, they are NLA for a long time. But, you can still find the optical sensor units, springs (i.e. grey, grey), and caps. It's a shame as they work great and can be tuned to your application. Our 1.8 uses a centrifugal distributor without dimpling the tin, YMMV. |
Lo-Fi Version | Time is now: 26th June 2024 - 09:45 AM |
