mb911 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,968 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest ![]() ![]() |
Steve |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,622 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California ![]() ![]() |
I would be interested if you made the whole metal rocker panel. For me, it’s too much hassle to find someone to weld it on and do the fit and finish to make it look right. My current car has Getty Design bolt on fiberglass rockers. I do know that some shops weld the flairs on without fitting the rockers first and then you have to jury rig the rockers to make it look right.
mb911 |
I would be interested if you made the whole metal rocker panel. For me, it’s too much hassle to find someone to weld it on and do the fit and finish to make it look right. My current car has Getty Design bolt on fiberglass rockers. I do know that some shops weld the flairs on without fitting the rockers first and then you have to jury rig the rockers to make it look right. Yes for sure. I have found there is no such thing as 1 size fits all on these cars. Each on is different and that is a problem. |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,334 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
I would be interested if you made the whole metal rocker panel. For me, it’s too much hassle to find someone to weld it on and do the fit and finish to make it look right. My current car has Getty Design bolt on fiberglass rockers. I do know that some shops weld the flairs on without fitting the rockers first and then you have to jury rig the rockers to make it look right. Yes for sure. I have found there is no such thing as 1 size fits all on these cars. Each on is different and that is a problem. I believe the proper way is to install the flares and then fit the rockers to the flares. Fender flares need to be fit properly to the wheel opening regardless of rocker length. They become a structural element of the car. Rocker covers are cosmetic. They fill in the gap between the flares but don’t determine it. Same with bumpers. You fit them to the car, not the opposite. |
Steve |
I would be interested if you made the whole metal rocker panel. For me, it’s too much hassle to find someone to weld it on and do the fit and finish to make it look right. My current car has Getty Design bolt on fiberglass rockers. I do know that some shops weld the flairs on without fitting the rockers first and then you have to jury rig the rockers to make it look right. Yes for sure. I have found there is no such thing as 1 size fits all on these cars. Each on is different and that is a problem. I believe the proper way is to install the flares and then fit the rockers to the flares. Fender flares need to be fit properly to the wheel opening regardless of rocker length. They become a structural element of the car. Rocker covers are cosmetic. They fill in the gap between the flares but don’t determine it. Same with bumpers. You fit them to the car, not the opposite. I guess I’m lucky then. My Getty rocker panels have not been modified and everything looks great including the front and rear GT valance. All bolt one. Beach boys racing installed them. |
mepstein |
I would be interested if you made the whole metal rocker panel. For me, it’s too much hassle to find someone to weld it on and do the fit and finish to make it look right. My current car has Getty Design bolt on fiberglass rockers. I do know that some shops weld the flairs on without fitting the rockers first and then you have to jury rig the rockers to make it look right. Yes for sure. I have found there is no such thing as 1 size fits all on these cars. Each on is different and that is a problem. I believe the proper way is to install the flares and then fit the rockers to the flares. Fender flares need to be fit properly to the wheel opening regardless of rocker length. They become a structural element of the car. Rocker covers are cosmetic. They fill in the gap between the flares but don’t determine it. Same with bumpers. You fit them to the car, not the opposite. I guess I’m lucky then. My Getty rocker panels have not been modified and everything looks great including the front and rear GT valance. All bolt one. Beach boys racing installed them. Yes, lucky. When I got my GT flares from AA during the group buy, I also purchased GT rocker panels. One was 3/4" of an inch longer than the other. I do like the idea of an all steel rear valance. Fiberglass often seems to crack around the mounting holes and won't survive a curb hit like metal. |
Lo-Fi Version | Time is now: 26th June 2024 - 01:51 PM |
