RandyE |
Newbie ![]() Group: Members Posts: 13 Joined: 5-March 22 From: california Member No.: 26,373 Region Association: None ![]() |
Does anyone know a good way to change the selector rod seal on the tail shift transmission? I want to change the oil seal. I removed the plate below the rod, and i see what appears to be a dowel pin holding the rod in place but the selector rod will not rotate enough to get a clear shot to hammer out that pin. Any thoughts?
mgphoto |
"If there is a mistake it will find me" ![]() ![]() ![]() Group: Members Posts: 1,341 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California ![]() |
Since the transmission is out the rear cover is easy to remove, pull off the cover, keep all the parts in order.
Once the shift rod is disengaged the pin can be rotated and immobilized for removal. Pin is a standardized part. |
Lo-Fi Version | Time is now: 26th June 2024 - 02:45 AM |
