> speedometer cable replacement, any tricks?
jfort
post Jan 12 2005, 03:33 PM
I did a search and didn't see anything. Probably too simple, but I can find a way to screw up the easiest task. I am looking at the factory manual. Replacing the speedo cable sounds easy but the pictures are not too good. Can someone describe the process? My gauges are out. Disconnect from transmission and pull it out? Fish the new one from rear to front?
Dave_Darling
post Jan 12 2005, 04:46 PM
914 Idiot
At one point, the cables were shipped with the rubber "boot" (goes over the tube where the cable passes through the firewall) on backwards. Check that before you start, or you'll have to take it back out again or mangle things...
I just pulled the whole shebang out from under the car, and fed the new one back in from the same location. No strings needed. I did, however, have to remove my center console, the center console change tray/cushion setup, and the center tunnel carpet.
--DD
jfort   speedometer cable replacement   Jan 12 2005, 03:33 PM
Porsche Rescue   I believe you only need to replace the inner cable...   Jan 12 2005, 03:56 PM
jim912928   I just replaced mine...entire sheath and all. It ...   Jan 12 2005, 04:34 PM
Porsche Rescue   I think Jim has the best advice. If cable is broke...   Jan 12 2005, 04:38 PM
jim912928   The entire speedo cable (sheath/insides/rubber boo...   Jan 12 2005, 04:42 PM
Dave_Darling   At one point, the cables were shipped with the rub...   Jan 12 2005, 04:46 PM
SGB   It wasn't quite as easy for me.... lessons lea...   Jan 12 2005, 04:46 PM
agrump     Jan 13 2005, 07:53 AM
jim912928   One thing I'd add about the string method (act...   Jan 13 2005, 09:06 AM
jfort   you guys are great. i appreciate your advice. i...   Jan 13 2005, 12:31 PM
jfort   I ordered and received from PP speedo cable # 914-...   Jan 17 2005, 09:54 AM
jim912928   Sounds like you've got the wrong part. When I...   Jan 17 2005, 12:36 PM
jwalters   http://www.914world.com/bbs2/html/e...   Jan 17 2005, 06:13 PM
jim912928   Well, mine slid right out with no problem (speed e...   Jan 17 2005, 07:59 PM
jdamiano   So if you decide to replace your speedometer cable...   Feb 16 2020, 11:09 AM
- Lo-Fi Version Time is now: 5th February 2025 - 08:41 AM
