speedometer cable replacement, any tricks? |
jfort |
Jan 12 2005, 03:33 PM
Senior Member Group: Members Posts: 1,146 Joined: 5-May 03 From: Findlay, OH Member No.: 652 Region Association: Upper MidWest |
I did a search and didn't see anything. Probably too simple, but I can find a way to screw up the easiest task. I am looking at the factory manual. Replacing the speedo cable sounds easy but the pictures are not too good. Can someone describe the process? My gauges are out. Disconnect from transmission and pull it out? Fish the new one from rear to front?
SGB |
Jan 12 2005, 04:46 PM
just visiting Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States |
It wasn't quite as easy for me....
lessons learned: Wire is stronger than string Removing center console was required to route cable- it exits near the shifter and runs in a depressed area below the carpet Remember to zip tie the cable around the engine (I sistered to clutch cable. Taking out seat reduces contortion necessary. Hardest part is getting the rubber grommet on at the firewall, but it is tough- use needle-nose pliers. |
Lo-Fi Version | Time is now: 5th February 2025 - 08:51 AM |
