Shivers |
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,490 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California ![]() |
Usual story, boy meets car, boy changes stuff and now wants to change stuff again. So I'm going side shift, got some used parts including a shifter., the shifter rod was buggered but the rest was okay. For my tail shifter I put in a short shift kit, it helped, now it was like stirring a small pot of stew instead of a large one. (IMG:style_emoticons/default/stirthepot.gif) So I also pulled the tail shifter apart to remove the shifter rod to replace the bad one on the side shifter and maybe pass this short shift kit on. When I finished I noticed this:
![]() Looking at the rest of the pieces that would add length for both shifters, they come out pretty even. So is this why I have had no luck finding a short shift kit for a 73 and up design? Can it go any lower into the tunnel? Looks like the factory did all they could to get a better shift in the later cars. Yup, Rennshift, love to have one but with my budget it would not be prudent. I'd like to make it harder to push the gate over so it isn't so easy to nick reverse . Anyone ever put washers in as shims behind the springs to tighten the tension? Any reason I should not? Thank You |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,643 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
Back in the day weltmeister used to make a stronger spring set up that provided additional resistance against the reverse plane
I have one in my car It was pretty difficult to install as the new stronger spring in the kit would barely fit on the pin in the shifter No reason you could not find the correct/heavier spring on belmetric and do the same |
Shivers |
Back in the day weltmeister used to make a stronger spring set up that provided additional resistance against the reverse plane I have one in my car It was pretty difficult to install as the new stronger spring in the kit would barely fit on the pin in the shifter No reason you could not find the correct/heavier spring on belmetric and do the same Does it work? Like when going from 4th to 2nd in a hurry? It doesn't move that far so it seemed to me any extra tension will help. And washers I can afford. (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 26th June 2024 - 01:06 AM |
