Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,994 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
I'm changing a ball joint on my 914 and can't figure out how to remove the nut with the 4 notches. Do I need a special tool to do this? How about a big pipe wrench or channel lock?
I used liquid wrench on it for a couple of days now. How to remove this sucker? The Star lock piece has been removed. Thanks, Spoke |
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
I bought that tool from Pelican and it stripped on the first try. The metal was a type that was weaker than the nut. Kinda dumb.
I ended up using a pipe wrench and it worked great. Replace the nuts ($14 ea) and use anti-sieze on the threads. You'll thank yourself later. If it wont budge with a wrench you can try a drift and hammer in one of the grooves, or cutting with a dremel (I had to do this on one, not fun at all). Its like splitting any other nut. |
Lo-Fi Version | Time is now: 25th June 2024 - 10:59 PM |
