JMT |
Newbie ![]() Group: Members Posts: 36 Joined: 19-August 16 From: Ca Member No.: 20,316 Region Association: None ![]() |
Hello everyone. Went for a drive today and car ran great, stopped for fuel and when I started back up I heard a horrible rattle coming from cylinders 3 and 4 valve cover. After a tow home I found this. At least 1/4" gap from rocker to valve tip. I turned the engine over slowly and did get the rocker arm to slightly open valve. I thought how could a solid lifter collapse?
I also pulled the rockers and pushrod. The pushrod was not bent. I looked down the pushrod tube and saw 'C' clips on the lifters. Is there such a thing as solid lifters with 'C' clips? Thank's for the help. ![]() |
JMT |
It was obvious that it’s hydraulic once I pulled it out. I was told this engine was built with a Webcam 86 so assumed it had solid lifters. Now what to do? Solid lifter swap.
Lo-Fi Version | Time is now: 25th June 2024 - 08:01 PM |
