What just happened ?, Final update 6/14/22 |
jim_hoyland |
Jun 12 2022, 01:00 PM
Get that VIN ? Group: Members Posts: 9,334 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I was humming along PCH and stopped at the 7-11. As I left the 7-11; put the car in firs, let outage clutch. I har this sound like the tranny popped out of gear. After that, no selected gear did anything. Engine runs fine, just can't drive.
Tjis was Friday, had the car towed to PCH garage, a couple of blocks away. Has anyone had this happen to them ? 914Toy,Keith, suggested several possibilities: 1. Cone screws at shifter rods 2. Roll pin in the short shift lever at the rear console 3. Inspect/turn each drive shaft independently and listen for noises and note motion The car has a recent Tangerine rear shift console modification. Any experience and/or suggestions will be appreciated. @Dr Evil |
Robarabian |
Jun 12 2022, 05:09 PM
914 A Roo Group: Members Posts: 593 Joined: 11-February 19 From: Simi Valley, Kalifornia Member No.: 22,865 Region Association: Southern California |
Ill second the CV joint. I heard a pop, had no movement. Everything seemed fine.. It was 1 of the joints. Almost guarantee that's it.
jim_hoyland |
Jun 12 2022, 06:21 PM
Ill second the CV joint. I heard a pop, had no movement. Everything seemed fine.. It was 1 of the joints. Almost guarantee that's it. What would it look like, is the damage obvious ? @Robarabian |
Robarabian |
Jun 12 2022, 06:30 PM
As @sirandy said, pull on the axle shafts. You will immediately notice it it broken. Will be alot of slop / free play. When they open it up, it'll be obvious. Usually the cage inside lets loose.
quote name='jim_hoyland' date='Jun 12 2022, 05:21 PM' post='3008236'] [quote name='Robarabian' post='3008227' date='Jun 12 2022, 04:09 PM'] Ill second the CV joint. I heard a pop, had no movement. Everything seemed fine.. It was 1 of the joints. Almost guarantee that's it. [/quote] What would it look like, is the damage obvious ? @Robarabian [/quote] |
Lo-Fi Version | Time is now: 25th June 2024 - 11:01 PM |
