jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,334 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
I was humming along PCH and stopped at the 7-11. As I left the 7-11; put the car in firs, let outage clutch. I har this sound like the tranny popped out of gear. After that, no selected gear did anything. Engine runs fine, just can't drive.
Tjis was Friday, had the car towed to PCH garage, a couple of blocks away. Has anyone had this happen to them ? 914Toy,Keith, suggested several possibilities: 1. Cone screws at shifter rods 2. Roll pin in the short shift lever at the rear console 3. Inspect/turn each drive shaft independently and listen for noises and note motion The car has a recent Tangerine rear shift console modification. Any experience and/or suggestions will be appreciated. @Dr Evil |
Montreal914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,599 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California ![]() ![]() |
So, which pinion failed?
The spider gears inside the differential assembly? ![]() Or the actual pinion from the ring and pinion? ![]() Clearly different repairs... (IMG:style_emoticons/default/sad.gif) That being said, maybe it is time for an overhaul... (IMG:style_emoticons/default/dry.gif) |
Lo-Fi Version | Time is now: 25th June 2024 - 10:50 PM |
