Crankcase Breather Recommendation |
barnfind9141972 |
Jun 21 2022, 08:53 PM
Member Group: Members Posts: 101 Joined: 10-December 20 From: Rancho Mirage, CA Member No.: 24,976 Region Association: Southern California |
Hi everyone, I went for a spirited drive last night and came back with a huge oily mess all over the engine. I have dual carbs and no crankcase breather as I wasn’t aware the need of one, what do you all recommend? I have a 1.7 block and heads that are now a 2056 and would like to put one in that is as simple as possible. Hoping something that just connects to the oil fill tower. Thanks!
mgphoto |
Jun 21 2022, 09:37 PM
"If there is a mistake it will find me" Group: Members Posts: 1,341 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Hi everyone, I went for a spirited drive last night and came back with a huge oily mess all over the engine. I have dual carbs and no crankcase breather as I wasn’t aware the need of one, what do you all recommend? I have a 1.7 block and heads that are now a 2056 and would like to put one in that is as simple as possible. Hoping something that just connects to the oil fill tower. Thanks! Simple way is as the factory did it, most the 1.7 oil towers have a breather where the PCV valve is located, cut a hole in one of the air cleaners braze in a small piece of pipe you can connect a hose from the breather. 1.8 oil tower has a pipe where the hole for the PCV valve goes, omits the valve. |
Lo-Fi Version | Time is now: 20th June 2024 - 09:17 AM |
