barnfind9141972 |
Member ![]() ![]() Group: Members Posts: 101 Joined: 10-December 20 From: Rancho Mirage, CA Member No.: 24,976 Region Association: Southern California ![]() |
Hi everyone, I went for a spirited drive last night and came back with a huge oily mess all over the engine. I have dual carbs and no crankcase breather as I wasn’t aware the need of one, what do you all recommend? I have a 1.7 block and heads that are now a 2056 and would like to put one in that is as simple as possible. Hoping something that just connects to the oil fill tower. Thanks!
mtndawg |
Member ![]() ![]() Group: Members Posts: 414 Joined: 26-January 09 From: Granite Bay, Ca Member No.: 9,985 Region Association: None ![]() ![]() |
This was on my last 2.0 with carbs. Catch can that was vented under the car. Kept everything neat and clean.
Attached thumbnail(s) ![]() |
barnfind9141972 |
This was on my last 2.0 with carbs. Catch can that was vented under the car. Kept everything neat and clean. @mtndawg @mtndawg looks awesome, that would be perfect. So to try to understand this, you have 2.0 heads which also vent correct? So you have oil vapor/air breathing from your oil tower and each head into the oil catch can, then filters, and comes out of the catch can which vents to the atmosphere and is simply air or vapor and not actual oil right? Do you remember where you sourced it? |
Lo-Fi Version | Time is now: 20th June 2024 - 09:21 AM |
