Geezer914 |
Geezer914 ![]() ![]() ![]() Group: Members Posts: 1,904 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States ![]() ![]() |
I am trying to adjust the air fuel ratio on me 2056 Ljet. I read the article that was posted a while back. I adjusted the wiper arm and set the idle at 1100 rpm (Raby 9550 cam) with the idle AFR at 13.2. When I check the high rpm the AFR is at 12.1. If I adjust the high rpm AFR to 13.2, (moving the large wheel 7 teeth CW) the the idle AFR is 16.9 with the mix screw all the way down. If I readjust the wiper arm to 13.2, then the high rpm AFR goes back to 12.2. Can't seem to find a happy medium. I know when you adjust the wiper arm it changes the mixture linear from idle to high rpm. How much more can I adjust the large wheel CW?
Geezer914 |
I ended up with 13.1 at 3000 rpm and 16.9 at idle. Just like Mark said, the idle is lean but not under load.
Lo-Fi Version | Time is now: 19th April 2025 - 01:16 PM |
