> Air fuel ratio Ljet
Geezer914
post Jun 19 2022, 01:44 PM
Geezer914
I am trying to adjust the air fuel ratio on me 2056 Ljet. I read the article that was posted a while back. I adjusted the wiper arm and set the idle at 1100 rpm (Raby 9550 cam) with the idle AFR at 13.2. When I check the high rpm the AFR is at 12.1. If I adjust the high rpm AFR to 13.2, (moving the large wheel 7 teeth CW) the the idle AFR is 16.9 with the mix screw all the way down. If I readjust the wiper arm to 13.2, then the high rpm AFR goes back to 12.2. Can't seem to find a happy medium. I know when you adjust the wiper arm it changes the mixture linear from idle to high rpm. How much more can I adjust the large wheel CW?
ClayPerrine
post Jun 29 2022, 06:32 AM
I don't ever recommend changing the settings on the internals of the AFM. It is setup at the factory with a certain spring tension and requires a special Bosch tool and manual to reset it correctly. Changing it can change the fuel curve dramatically and cause crappy running.
If your AFM has been opened, I suggest you get one that has not been touched and try it. You may find the majority of your problems go away after that.
Clay
Geezer914   Air fuel ratio Ljet   Jun 19 2022, 01:44 PM
emerygt350   Is any of this under load?   Jun 19 2022, 05:08 PM
Geezer914   No. The idle is going to be the idle. The only t...   Jun 19 2022, 05:31 PM
emerygt350   No. The idle is going to be the idle. The only ...   Jun 19 2022, 05:39 PM
Mark Henry   Load AFR with iron jugs should be just under 13:1,...   Jun 20 2022, 09:26 AM
914werke   Sounds like were on a parallel path. Following Im ...   Jun 20 2022, 12:37 PM
Van B   Geezer, seems to me you were fine with the values ...   Jun 21 2022, 10:02 AM
914werke   Hopefully the Geez is making better progress than ...   Jun 23 2022, 07:48 PM
Van B   Hmmm… AFM screw is 3-4 turns out, correct? What...   Jun 23 2022, 08:51 PM
Geezer914   If your idle is high and no change when you adjust...   Jun 24 2022, 04:31 AM
Geezer914   I ended up with 13.1 at 3000 rpm and 16.9 at idle....   Jun 24 2022, 04:34 AM
914werke   If your idle is high and no change when you adjus...   Jun 24 2022, 09:17 AM
ClayPerrine   If your idle is high and no change when you adju...   Jun 24 2022, 02:33 PM
Van B   There is no 27 degree mark for the L-Jet. I wonde...   Jun 24 2022, 12:21 PM
rhodyguy   Something is amiss down wind of the AFM? Vac leak ...   Jun 24 2022, 01:01 PM
914werke   Thanks for chiming in Clay. @ClayPerrine Ive ne...   Jun 24 2022, 02:51 PM
wonkipop   Thanks for chiming in Clay. [b]@[url=http://www....   Jun 24 2022, 06:25 PM
Van B   On last time: Does your fan have the single red pa...   Jun 24 2022, 03:28 PM
wonkipop   On last time: Does your fan have the single red p...   Jun 24 2022, 05:08 PM
wonkipop   from factory manual on timing marks. (interesting...   Jun 24 2022, 05:36 PM
914werke   So thanks to all who chimed in. Sometime you get ...   Jun 24 2022, 07:08 PM
wonkipop   good stuff. :beer2: good looking throttle body....   Jun 24 2022, 07:21 PM
Van B   Ah yeah that’ll do it. When you said TB was goo...   Jun 24 2022, 07:26 PM
914werke   UGH. Im back. Well I thought I have this dicked b...   Jun 28 2022, 03:44 PM
wonkipop   i'm probably not much help - i have an entirel...   Jun 28 2022, 07:11 PM
ClayPerrine   I don't ever recommend changing the settings o...   Jun 29 2022, 06:32 AM
Van B   I don't ever recommend changing the settings ...   Jun 29 2022, 11:28 PM
914werke   I don't ever recommend changing the settings ...   Jun 29 2022, 04:55 PM
ClayPerrine   [quote name='ClayPerrine' post='3012025' date='Ju...   Jun 30 2022, 04:59 AM
Geezer914   Look up Internet Air Cooled Air Flow Meter. There...   Jun 29 2022, 07:08 PM
914werke   Just an FYI.. I had factory training on L-Jet ba...   Jun 30 2022, 12:37 PM
wonkipop   Just an FYI.. I had factory training on L-Jet b...   Jun 30 2022, 06:19 PM
ClayPerrine   Just an FYI.. I had factory training on L-Jet b...   Jul 1 2022, 05:39 AM
914werke   Rich, I apologize if I came across as admonishin...   Jul 1 2022, 11:01 AM
ClayPerrine   [quote name='ClayPerrine' post='3012437' date='Ju...   Jul 1 2022, 01:36 PM
StarBear   [quote name='ClayPerrine' post='3012437' date='J...   Jul 3 2022, 06:48 AM
nihil44   I have been outed by @wonkipop . I have been loit...   Jul 4 2022, 06:41 PM
914werke   here's what Im working with:   Jul 1 2022, 03:00 PM
wonkipop   thats a 75 1.8 AFM. i believe it pairs with a 75 ...   Jul 1 2022, 08:45 PM
ClayPerrine   thats a 75 1.8 AFM. i believe it pairs with a 75...   Jul 2 2022, 06:24 AM
wonkipop   part #s / details for the L Jet components on a 91...   Jul 1 2022, 09:49 PM
wonkipop   @914werke some one who might be able to help wit...   Jul 2 2022, 07:56 PM
ClayPerrine   I don't understand why you would have to ...   Jul 4 2022, 08:10 PM
nihil44   Clay, I was just having a play with the Kombi AFM...   Jul 4 2022, 08:32 PM
wonkipop   thanks for the images @nihil44 great to be able...   Jul 4 2022, 08:40 PM
Van B   That ‘74 6 pin doesn’t look like either of min...   Jul 4 2022, 11:19 PM
nihil44   Apologies to the group for posting photos of what ...   Jul 5 2022, 08:37 PM
- Lo-Fi Version Time is now: 14th December 2025 - 05:14 AM
