Ampex351 |
Member ![]() ![]() Group: Members Posts: 104 Joined: 8-April 20 From: Roseburg, Oregon Member No.: 24,115 Region Association: Pacific Northwest ![]() |
The frunk lock got locked from the handle inside and now it won't unlock. I've tried lubing the lock and turning either way but it just won't unlock. Any ideas?
Thanks! |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,334 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
You can remove the front bumper and flip the latch through a small hole that is already in the front latch area. I’ve done it and it was easy.
Then lube everything up, including the cable housing. |
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,708 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
You can remove the front bumper and flip the latch through a small hole that is already in the front latch area. I’ve done it and it was easy. Then lube everything up, including the cable housing. (IMG:style_emoticons/default/agree.gif) found that little plug when I removed my bumper to do various jobs,Mark do you think this will work for the OP if the handle is locked,thinking this may stop the latch release from working ??. |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,549 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
You can remove the front bumper and flip the latch through a small hole that is already in the front latch area. I’ve done it and it was easy. Then lube everything up, including the cable housing. (IMG:style_emoticons/default/agree.gif) found that little plug when I removed my bumper to do various jobs,Mark do you think this will work for the OP if the handle is locked,thinking this may stop the latch release from working ??. It can still be opened by tripping the latch. |
Lo-Fi Version | Time is now: 26th June 2024 - 04:08 AM |
