Ampex351 |
Member ![]() ![]() Group: Members Posts: 104 Joined: 8-April 20 From: Roseburg, Oregon Member No.: 24,115 Region Association: Pacific Northwest ![]() |
The frunk lock got locked from the handle inside and now it won't unlock. I've tried lubing the lock and turning either way but it just won't unlock. Any ideas?
Thanks! |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,334 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
You can remove the front bumper and flip the latch through a small hole that is already in the front latch area. I’ve done it and it was easy.
Then lube everything up, including the cable housing. |
Ampex351 |
You can remove the front bumper and flip the latch through a small hole that is already in the front latch area. I’ve done it and it was easy. Then lube everything up, including the cable housing. I finally got it without removing the bumper. Just kept wiggling the danged key and it popped loose and unlocked! Thanks for the tip about removing bumper just in case. |
Lo-Fi Version | Time is now: 26th June 2024 - 04:25 AM |
