StarBear |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,112 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States ![]() ![]() |
As getting ready for the 2022 Northeast Gathering, I'm encountering a semi-recurring idle issue on my 1974 1.8L LJet FI. When outside air is cool and dry, idles just fine at 950-1000 rpm. When outside air is warm and humid, after warmup the idle falls off to barely running. I've just been adjusting the air flow screw (maybe 1.5-2 full turns) to open it. Of course, the reverse happens - if I preadjust the screw it idles near 1800 then settles down to 1100 after the engine gets totally warm (15 mins or so).
I presume (?) there SHOULD be some regulation, perhaps with the ECU or AFM, to monitor air temp and humidity and make adjustments automatically? I didn't have to manually do this adjustment in the past. The AAR works and tests out fine. Just annoying to have to pull over after running a while and adjust the screw. (IMG:style_emoticons/default/dry.gif) Your thoughts @Van @Van_B and @Wonkipop ? |
wonkipop |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,738 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille ![]() ![]() |
oh yeah steve. a loose oil cap will make your idle stumble and die, even a tiny bit loose.
Lo-Fi Version | Time is now: 12th April 2025 - 01:01 AM |
