> Idle Speed and Air Temp/Humidity
StarBear
post Jun 29 2022, 12:46 PM
As getting ready for the 2022 Northeast Gathering, I'm encountering a semi-recurring idle issue on my 1974 1.8L LJet FI. When outside air is cool and dry, idles just fine at 950-1000 rpm. When outside air is warm and humid, after warmup the idle falls off to barely running. I've just been adjusting the air flow screw (maybe 1.5-2 full turns) to open it. Of course, the reverse happens - if I preadjust the screw it idles near 1800 then settles down to 1100 after the engine gets totally warm (15 mins or so).
I presume (?) there SHOULD be some regulation, perhaps with the ECU or AFM, to monitor air temp and humidity and make adjustments automatically? I didn't have to manually do this adjustment in the past.
The AAR works and tests out fine. Just annoying to have to pull over after running a while and adjust the screw. (IMG:style_emoticons/default/dry.gif)
Your thoughts @Van @Van_B and @Wonkipop ?
ClayPerrine
post Jul 3 2022, 02:27 PM
In reference to the air flow meter, the air temp sensor is in both the 74 and the 75, but the wiring is different. In 74, it shared a common wire with the wiper contacts. In 75, they separated it out because of electrical interference.
Double check the ECU number is correct for the year of the car. A 75 ECU on a 74 car will fit, start and run, but the air temp sensor will not work at all. Same goes for a 74 ECU on a 75 car.
The comment about the throttle body being worn is also very good. I had fits with the idle on Betty's car for a while, until we got a 2.1 Bus throttle body. Once I did that, the idle seemed to get much more stable.
Clay
StarBear
post Jul 3 2022, 04:12 PM
QUOTE(ClayPerrine @ Jul 3 2022, 04:27 PM) *
Clay
@clayperrine Thanks, Clay. It is the correct ECU, as I'm the original owner and swapped a matching number ECU several years ago. This issue just started when the weather got warmer.
Can the sensor in a 6-pin 74 AFM be replaced (even if difficult)?
Will try the throttle body test, as Van suggested.
StarBear   Idle Speed and Air Temp/Humidity   Jun 29 2022, 12:46 PM
StarBear   CHT Sensor? Rpm seems to stay steady if air stays ...   Jun 29 2022, 01:32 PM
wonkipop   only thing i can think of is the other temp sensor...   Jun 29 2022, 05:28 PM
StarBear   Will try cleaning those plugs. Grounds are A+ and ...   Jun 29 2022, 07:30 PM
Van B   Steve, sorry for the delay, I’ve been traveling ...   Jun 29 2022, 11:20 PM
wonkipop   Steve, sorry for the delay, I’ve been traveling...   Jun 29 2022, 11:47 PM
StarBear   Steve, sorry for the delay, I’ve been traveling...   Jun 30 2022, 05:59 AM
wonkipop   Steve, sorry for the delay, I’ve been travelin...   Jun 30 2022, 04:36 PM
StarBear   next time it’s all hot and steamy, you should ...   Jun 30 2022, 07:52 PM
Van B   next time it’s all hot and steamy, you should...   Jun 30 2022, 09:15 PM
StarBear   [quote name='StarBear' post='3012404' date='Jun 3...   Jul 1 2022, 09:54 AM
Van B   On these cars idle is far more likely to climb fro...   Jun 29 2022, 11:24 PM
Van B   Check it all the same. But, it seems to me that y...   Jun 30 2022, 01:28 PM
StarBear   @Van B and [b]@[url=http://www.914world.com/bbs2...   Jun 30 2022, 04:52 PM
Van B   The Porsche manual does a terrible job of breaking...   Jun 30 2022, 04:56 PM
StarBear   The Porsche manual does a terrible job of breakin...   Jun 30 2022, 05:27 PM
StarBear   Ok, looking at Haynes page 177 on fig 9.87 current...   Jun 30 2022, 05:43 PM
wonkipop   Ok, looking at Haynes page 177 on fig 9.87 curren...   Jun 30 2022, 06:03 PM
wonkipop   oh yeah steve. a loose oil cap will make your id...   Jun 30 2022, 06:05 PM
wonkipop   @StarBear i looked through the electrical schema...   Jul 1 2022, 08:51 PM
StarBear   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Jul 2 2022, 06:26 AM
wonkipop   ok @StarBear . i had to keep digging. as i do. ...   Jul 2 2022, 02:18 AM
StarBear   (i leave this with [b]@[url=http://www.914worl...   Jul 2 2022, 06:30 AM
Van B   (i leave this with [b]@[url=http://www.914wor...   Jul 2 2022, 08:32 AM
Van B   Also, still think there's nothing really wrong...   Jul 2 2022, 08:34 AM
StarBear   Also, still think there's nothing really wron...   Jul 2 2022, 09:45 AM
wonkipop   Also, still think there's nothing really wron...   Jul 2 2022, 05:11 PM
Van B   Yeah, you’re a native for sure. Did you buy the...   Jul 2 2022, 10:38 AM
StarBear   Yeah, you’re a native for sure. Did you buy th...   Jul 2 2022, 07:48 PM
wonkipop   Yeah, you’re a native for sure. Did you buy t...   Jul 2 2022, 08:11 PM
Van B   That’s a differ AFM than both of mine. The one I...   Jul 2 2022, 05:30 PM
wonkipop   That’s a differ AFM than both of mine. The one ...   Jul 2 2022, 06:02 PM
wonkipop   i'm just curious about it @[url=http://www...   Jul 2 2022, 06:31 PM
wonkipop   its cold down here today. almost new jersey or mar...   Jul 2 2022, 10:28 PM
StarBear   @wonkipop Yep, we’re just a few miles north o...   Jul 3 2022, 06:45 AM
StarBear   @clayperrine Would you mind chiming in on this w...   Jul 3 2022, 06:58 AM
StarBear   Update: Had a nice 30+ minute run today including ...   Jul 3 2022, 09:27 AM
wonkipop   Update: Had a nice 30+ minute run today including...   Jul 3 2022, 06:06 PM
Van B   Update: Had a nice 30+ minute run today including...   Jul 4 2022, 09:53 AM
ClayPerrine   In reference to the air flow meter, the air temp s...   Jul 3 2022, 02:27 PM
StarBear   In reference to the air flow meter, the air temp ...   Jul 3 2022, 04:12 PM
StarBear   @wonkipop [b]@[url=http://www.914world.com/bbs2...   Jul 4 2022, 09:47 AM
Van B   What I previously described is my method to see if...   Jul 4 2022, 10:00 AM
StarBear   Solved, I think/hope. Did the TB test suggested b...   Jul 4 2022, 12:33 PM
ClayPerrine   Still begs the answer to all our questions about ...   Jul 4 2022, 01:18 PM
StarBear   Still begs the answer to all our questions about...   Jul 4 2022, 01:58 PM
Van B   Resistance figures outlined in the manual are all ...   Jul 4 2022, 03:13 PM
ClayPerrine   Resistance figures outlined in the manual are all...   Jul 4 2022, 03:46 PM
StarBear   Resistance figures outlined in the manual are al...   Jul 4 2022, 05:03 PM
wonkipop   you might have fixed it @StarBear . :beer2: a...   Jul 4 2022, 08:14 PM
Van B   I wouldn’t take those pics of the ‘74 as certa...   Jul 4 2022, 11:21 PM
wonkipop   I wouldn’t take those pics of the ‘74 as cert...   Jul 4 2022, 11:28 PM
wonkipop   @StarBear . just noticed something about your T/B...   Jul 5 2022, 01:19 AM
StarBear   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Jul 5 2022, 05:52 AM
StarBear   Update 2: + did the pin tests in cool garage with ...   Jul 5 2022, 07:24 AM
StarBear   Second test run for 20 min done. Pins 6-9 at 324 ...   Jul 5 2022, 09:55 AM
nihil44   Apologies to the group for posting photos of what ...   Jul 5 2022, 06:00 PM
Van B   Yeah that is definitely the ‘74 AFM right there...   Jul 5 2022, 07:39 PM
wonkipop   Yeah that is definitely the ‘74 AFM right there...   Jul 6 2022, 06:11 PM
13 User(s) are reading this topic (13 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 12th April 2025 - 01:17 AM
