> Air fuel ratio Ljet
Geezer914
post Jun 19 2022, 01:44 PM
Geezer914
I am trying to adjust the air fuel ratio on me 2056 Ljet. I read the article that was posted a while back. I adjusted the wiper arm and set the idle at 1100 rpm (Raby 9550 cam) with the idle AFR at 13.2. When I check the high rpm the AFR is at 12.1. If I adjust the high rpm AFR to 13.2, (moving the large wheel 7 teeth CW) the the idle AFR is 16.9 with the mix screw all the way down. If I readjust the wiper arm to 13.2, then the high rpm AFR goes back to 12.2. Can't seem to find a happy medium. I know when you adjust the wiper arm it changes the mixture linear from idle to high rpm. How much more can I adjust the large wheel CW?
ClayPerrine
post Jul 4 2022, 08:10 PM
I don't understand why you would have to "cut and weld" the intake runners. A little tweaking side to side and the 2.0 Runners fit the 1.8 intake plenum fine. Yes, they are a little short, but that can be compensated for.
I wouldn't mess with using a Kombi AFM on a 914. Unlike current fuel injection, the parts on the early systems like the 914 L-Jet are matched and don't really work well when mismatched.
Good luck.
Clay
nihil44
post Jul 4 2022, 08:32 PM
Clay,
I was just having a play with the Kombi AFM just for interest. I am not intending to deviate from the '75 AFM ECU combination.
Geezer914   Air fuel ratio Ljet   Jun 19 2022, 01:44 PM
emerygt350   Is any of this under load?   Jun 19 2022, 05:08 PM
Geezer914   No. The idle is going to be the idle. The only t...   Jun 19 2022, 05:31 PM
emerygt350   No. The idle is going to be the idle. The only ...   Jun 19 2022, 05:39 PM
Mark Henry   Load AFR with iron jugs should be just under 13:1,...   Jun 20 2022, 09:26 AM
914werke   Sounds like were on a parallel path. Following Im ...   Jun 20 2022, 12:37 PM
Van B   Geezer, seems to me you were fine with the values ...   Jun 21 2022, 10:02 AM
914werke   Hopefully the Geez is making better progress than ...   Jun 23 2022, 07:48 PM
Van B   Hmmm… AFM screw is 3-4 turns out, correct? What...   Jun 23 2022, 08:51 PM
Geezer914   If your idle is high and no change when you adjust...   Jun 24 2022, 04:31 AM
Geezer914   I ended up with 13.1 at 3000 rpm and 16.9 at idle....   Jun 24 2022, 04:34 AM
914werke   If your idle is high and no change when you adjus...   Jun 24 2022, 09:17 AM
ClayPerrine   If your idle is high and no change when you adju...   Jun 24 2022, 02:33 PM
Van B   There is no 27 degree mark for the L-Jet. I wonde...   Jun 24 2022, 12:21 PM
rhodyguy   Something is amiss down wind of the AFM? Vac leak ...   Jun 24 2022, 01:01 PM
914werke   Thanks for chiming in Clay. @ClayPerrine Ive ne...   Jun 24 2022, 02:51 PM
wonkipop   Thanks for chiming in Clay. [b]@[url=http://www....   Jun 24 2022, 06:25 PM
Van B   On last time: Does your fan have the single red pa...   Jun 24 2022, 03:28 PM
wonkipop   On last time: Does your fan have the single red p...   Jun 24 2022, 05:08 PM
wonkipop   from factory manual on timing marks. (interesting...   Jun 24 2022, 05:36 PM
914werke   So thanks to all who chimed in. Sometime you get ...   Jun 24 2022, 07:08 PM
wonkipop   good stuff. :beer2: good looking throttle body....   Jun 24 2022, 07:21 PM
Van B   Ah yeah that’ll do it. When you said TB was goo...   Jun 24 2022, 07:26 PM
914werke   UGH. Im back. Well I thought I have this dicked b...   Jun 28 2022, 03:44 PM
wonkipop   i'm probably not much help - i have an entirel...   Jun 28 2022, 07:11 PM
ClayPerrine   I don't ever recommend changing the settings o...   Jun 29 2022, 06:32 AM
Van B   I don't ever recommend changing the settings ...   Jun 29 2022, 11:28 PM
914werke   I don't ever recommend changing the settings ...   Jun 29 2022, 04:55 PM
ClayPerrine   [quote name='ClayPerrine' post='3012025' date='Ju...   Jun 30 2022, 04:59 AM
Geezer914   Look up Internet Air Cooled Air Flow Meter. There...   Jun 29 2022, 07:08 PM
914werke   Just an FYI.. I had factory training on L-Jet ba...   Jun 30 2022, 12:37 PM
wonkipop   Just an FYI.. I had factory training on L-Jet b...   Jun 30 2022, 06:19 PM
ClayPerrine   Just an FYI.. I had factory training on L-Jet b...   Jul 1 2022, 05:39 AM
914werke   Rich, I apologize if I came across as admonishin...   Jul 1 2022, 11:01 AM
ClayPerrine   [quote name='ClayPerrine' post='3012437' date='Ju...   Jul 1 2022, 01:36 PM
StarBear   [quote name='ClayPerrine' post='3012437' date='J...   Jul 3 2022, 06:48 AM
nihil44   I have been outed by @wonkipop . I have been loit...   Jul 4 2022, 06:41 PM
914werke   here's what Im working with:   Jul 1 2022, 03:00 PM
wonkipop   thats a 75 1.8 AFM. i believe it pairs with a 75 ...   Jul 1 2022, 08:45 PM
ClayPerrine   thats a 75 1.8 AFM. i believe it pairs with a 75...   Jul 2 2022, 06:24 AM
wonkipop   part #s / details for the L Jet components on a 91...   Jul 1 2022, 09:49 PM
wonkipop   @914werke some one who might be able to help wit...   Jul 2 2022, 07:56 PM
ClayPerrine   I don't understand why you would have to ...   Jul 4 2022, 08:10 PM
nihil44   Clay, I was just having a play with the Kombi AFM...   Jul 4 2022, 08:32 PM
wonkipop   thanks for the images @nihil44 great to be able...   Jul 4 2022, 08:40 PM
Van B   That ‘74 6 pin doesn’t look like either of min...   Jul 4 2022, 11:19 PM
nihil44   Apologies to the group for posting photos of what ...   Jul 5 2022, 08:37 PM
- Lo-Fi Version Time is now: 14th December 2025 - 05:16 AM
