NARP74 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,084 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains ![]() |
Rubbing on the inside fender well on the right rear, passenger side. Rubbing on the outside fender on the left rear driver side. Showing a little heat in the paint on the left side. I may need to go to a smaller size tire in the back, they are staggered now. Can the arms be adjusted or shimmed? Seems like they are not centering the wheels in the openings. Just starting to work on a new project.
NARP74 |
Not sure which of the 2 POs installed these;
Rear is Fuchs 5 lug, 8 J 16 w/ 215 55 16 Front is Fuchs 5 lug 7 J 16 w/205 55 16 these seem fine Camber is on my list, an alignment is in order. Need to get some shims first. Tires rubbing is a good thing. Great comment! |
burton73 |
burton73 ![]() ![]() ![]() ![]() Group: Members Posts: 3,567 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California ![]() ![]() |
Not sure which of the 2 POs installed these; Rear is Fuchs 5 lug, 8 J 16 w/ 215 55 16 Front is Fuchs 5 lug 7 J 16 w/205 55 16 these seem fine Camber is on my list, an alignment is in order. Need to get some shims first. Tires rubbing is a good thing. Great comment! Up front 7s work fine but may scrape in a full turn of steering wheel when going up a driveway. You just have to go slow with that "Rear is Fuchs 5 lug, 8 J 16 w/ 215 55 16" Is this a 951 number or a 911 number on wheels? I take it that you are a stock body on car no flares? let us know. Bob B |
Lo-Fi Version | Time is now: 26th June 2024 - 12:53 AM |
