Rear window seal failure, Getting too hot from the Subie motor? |
theer |
Jul 25 2022, 12:05 PM
Senior Member Group: Members Posts: 681 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States |
Question for the intelligentsia:
My rear window seal failed on my Subie-swapped car, and I've noticed the firewall gets really warm. There's no backpad (yet), but there is a layer of sound deadening on the inside. No engine compartment pad, either. I can feel the heat radiating off the firewall. I haven't taken the temp, but I'd guess it's 120-130 degrees. Perfect for those 90+ degree summer days. The fresh air fan is not installed (yet) either, and my ice-powered swamp cooler contraption just can't compete. Driving home yesterday, I noticed the window glass was actually warm to the touch and thought perhaps the heat is causing the butyl seal to soften and the weight of the glass pulls itself off. I recently put the stock air flaps underneath in the hope that they would draw more cooling air through. No discernable difference. Anyone else getting that kind of heat from their engine compartment? Would the engine compartment pad help? How do others get the heat to flow out? Thanks, Tom |
Costa05 |
Jul 25 2022, 05:42 PM
Member Group: Members Posts: 320 Joined: 27-October 16 From: Phoenix, Arizona Member No.: 20,535 Region Association: Southwest Region |
I took these temps about a month ago on my recent 2.5 Subaru build just to see what was going on with my car. Note: radiator is in the front of the car. One of those smaller VW Sirocco radiator units. Engine sits back away from the firewall about 10" or more so there is a big space there, and I have not installed my engine lid yet so it is wide open to let the hot air to rise out. Coolant temps at the gauge is about 190ish. Temps as noted measured with a cheap HF infrared thermometer. The key could be in the engine lid removed or going with a GT style with full open venting. Hope this helps. Air temp100d sundown Engine intake iron manifold runner mid point 152d Engine top of alum cylinder head L 170 Engine top of alum cylinder head R 175 Alum intake tube steel support bracket 135d Alum intake tube at 75d bend 122d Alum intake tube at mid point 121d Alum intake tube at air cleaner 116d Fuel tank top center 106d Firewall front trunk radiator side at Moroso125d Alum expansion tank center 126d Firewall front cabin side metal 104d Console tunnel top - 3" behind shifter 101d Cabin floorplan cabin side on butyl insulation. Cabin perlon carpet passenger side feet area 100d Firewall back engine bay side midway 114d Firewall back cabin side carpet 103d Rear trunk decking mid point Radiator hose front 145d |
Lo-Fi Version | Time is now: 21st September 2024 - 07:01 PM |
