Sand blaster chassis then what ?, What would do next ? |
914GTSTI |
Jul 28 2022, 12:27 PM
Member Group: Members Posts: 270 Joined: 16-September 07 From: Glendale AZ Member No.: 8,123 Region Association: None |
Going to have my chassis sand blasted. What next steps do you guy's do ?
Randy |
nivekdodge |
Jul 29 2022, 11:50 AM
Member Group: Members Posts: 269 Joined: 28-August 21 From: Pittsburgh Pa Member No.: 25,860 Region Association: MidAtlantic Region |
20 years as a painter and then 20 as the local paint guy.
1.Rust gets almost everywhere, sand gets almost everywhere, acid almost gets everywhere. 2.The only people who had a chance at this not rusting back were the Germans 50 years ago when the metal was still pristine. If you have a 10 year old pickup truck you know about rust between two pieces of metal. 3. I stripped my outer panels with liquid and mechanical. Don't sandblast outer panels. You will warp them. The inner panels I did a combo of liquid, wire brush and mechanical.then sand blasting. 4. The Eastwood thing works great on truck frame rails. Not these body panels. 5. it either time or dollars, 6. blowing the sand out takes time. less with two airlines.Less with a spit. I spun mine every night and still got sand. I did a drag car years ago and everytime the wheels come back down, sand falls. How much is dipping? you MUST get the primer dipped also. Kevin |
930cabman |
Jul 29 2022, 12:52 PM
Advanced Member Group: Members Posts: 3,640 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
20 years as a painter and then 20 as the local paint guy. 1.Rust gets almost everywhere, sand gets almost everywhere, acid almost gets everywhere. 2.The only people who had a chance at this not rusting back were the Germans 50 years ago when the metal was still pristine. If you have a 10 year old pickup truck you know about rust between two pieces of metal. 3. I stripped my outer panels with liquid and mechanical. Don't sandblast outer panels. You will warp them. The inner panels I did a combo of liquid, wire brush and mechanical.then sand blasting. 4. The Eastwood thing works great on truck frame rails. Not these body panels. 5. it either time or dollars, 6. blowing the sand out takes time. less with two airlines.Less with a spit. I spun mine every night and still got sand. I did a drag car years ago and everytime the wheels come back down, sand falls. How much is dipping? you MUST get the primer dipped also. Kevin Kevin, Sounds as the voice of experience, there is no easy answer. I can recall blasting a pre-A speedster in the early 1970's with silica (without a mask) and there was sand everywhere, probably still is |
Lo-Fi Version | Time is now: 31st October 2024 - 08:21 PM |
