Attention Electrical Gurus, Need help with windshield washer wiring |
bbrock |
Jul 28 2022, 07:17 PM
Right after ordering a complete Car Magic kit to convert my windshield washer to electric, I read Sir Andy's excellent tech article on the conversion. The idea of pulling power for the washer pump off the intermittent wiper feed so the washer is activated by pulling back on the wiper lever was too elegant not to try.
I happened to have this nifty vintage VW style splitter I bought some time ago for not other reason than I thought it might come in handy for some future custom wiring project. It was just the ticket for splitting off of my intermittent washer relay to power the washer pump. After hooking everything up, I pulled back on the wiper lever and HUZZAH! The washers squirted and the wipers ran for two sweeps and parked. Pretty slick! I couldn't understand how the intermittent wipers would work when the lever was pulled down to turn the intermittent wipers on. I pull down on the lever to test them and nothing. As soon as I unplug the washer pump, the intermittent wipers start running. I'm not sure how the intermittent relay works, but thinking the timer is from charging a capacitor which then "bump starts" the wipers to run a single cycle. Is there is a reasonably simple way to isolate the pump so it allows the intermittent mechanism to run without activating the washer pump? Could be a fun project. Or should I just go back to the original plan of installing the Car Magic switch? I just like the idea of minimizing the wiring. |
Spoke |
Jul 29 2022, 09:54 PM
Jerry Group: Members Posts: 6,992 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
@bbrock
I'm not sure how pulling back on the stalk energizes the washer as that function was originally a pressure hose going to the tank and tire. On my '74 I replaced that valve with a microswitch and ran a wire to the washer motor. I had to click the stalk down to get the wiper to run. |
bbrock |
Jul 29 2022, 10:40 PM
@bbrock I'm not sure how pulling back on the stalk energizes the washer as that function was originally a pressure hose going to the tank and tire. On my '74 I replaced that valve with a microswitch and ran a wire to the washer motor. I had to click the stalk down to get the wiper to run. Yes, but the trick is that pulling back on the stalk energizes the brown/black S1 wire to run the wipers for two cycles (Sir Andy says it does 4 in his post, but mine does 2). So splitting off the S1 intermittent wire gives you 12v to send to the washer pump when the lever is pulled back. That part works and it pretty darn slick. But when I pull the lever down, I no longer get intermittent action. If you have intermittent on your 74, I'm not sure why the wiper isn't running when you pull back on the lever (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 20th June 2024 - 06:06 AM |
