Monday, 7 April 2025
> Attention Electrical Gurus, Need help with windshield washer wiring
bbrock
post Jul 28 2022, 07:17 PM
Right after ordering a complete Car Magic kit to convert my windshield washer to electric, I read Sir Andy's excellent tech article on the conversion. The idea of pulling power for the washer pump off the intermittent wiper feed so the washer is activated by pulling back on the wiper lever was too elegant not to try.
I happened to have this nifty vintage VW style splitter I bought some time ago for not other reason than I thought it might come in handy for some future custom wiring project. It was just the ticket for splitting off of my intermittent washer relay to power the washer pump.
After hooking everything up, I pulled back on the wiper lever and HUZZAH! The washers squirted and the wipers ran for two sweeps and parked. Pretty slick! I couldn't understand how the intermittent wipers would work when the lever was pulled down to turn the intermittent wipers on. I pull down on the lever to test them and nothing. As soon as I unplug the washer pump, the intermittent wipers start running. I'm not sure how the intermittent relay works, but thinking the timer is from charging a capacitor which then "bump starts" the wipers to run a single cycle.
Is there is a reasonably simple way to isolate the pump so it allows the intermittent mechanism to run without activating the washer pump? Could be a fun project. Or should I just go back to the original plan of installing the Car Magic switch? I just like the idea of minimizing the wiring.
lesorubcheek
post Jul 29 2022, 07:47 PM
I know the feeling. You just can't let this go without solving it. From the diagram, you can see a connection from a contact on the pull circuit (right 2 contacts) to the input of S1, so you can visualize that just pulling back on the lever will energize the intermittent action, just as 53c should be energized when pulling back on the stalk.
The part I can't visualize from the diagram is what's going on at S1 when the stalk is down or in the J position. It doesn't look like it's connecting to anything if you rock the angle up or clockwise one tick in the diagram. It looks like 53e will connect with 53, just as in the off position, which makes sense as that would connect the output from the intermittent relay to the low speed wiper. I'd expect 53a which is the 12V input to the switch to be connected with S1 when the switch is in the J position..... maybe it is, it just doesn't look clear in the diagram.
Dan
bbrock
post Jul 29 2022, 10:52 PM
QUOTE(lesorubcheek @ Jul 29 2022, 07:47 PM) *
Dan
Here is a better pic of the switch circuit. [Bad info]: Looks like the J position connects S1 and 53a and any other position sends it to ground except when the lever is pulled back if I'm reading this right. My DMM tells me with the lever in position J, I'm getting 12v at the relay end of S1 and 0v in the off position so that agrees. Actually I'm reading 11v because I have a low battery due to a busted alternator I replaced tonight. I'll get the battery fully charged and see what it reads.
Spoke
post Jul 31 2022, 04:44 PM
Jerry
I've been following this discussion but haven't chimed in because I'm severely confused on the operation.
I'm trying to understand this switch function. Please let me know if I've got this correct.
Switch positions:
J : Stalk pulled back; Relates to left-most selection of the contacts.
0 : Wipers off
1 : Wipers on low speed
2 : Wipers on high speed.
Contact S1:
J : No connection
0 : Ground
1 : Ground
2 : 12V
Did I get this right?
bbrock
post Jul 31 2022, 05:09 PM
QUOTE(Spoke @ Jul 31 2022, 04:44 PM) *
Switch positions:
0 : Wipers off
Contact S1:
J : No connection
0 : Ground
1 : Ground
2 : 12V
Ah! There is something I should have explained early that will not be obvious unless you have messed with the intermittent option. J is lever pulled down and is not available by default. There is a plastic tab in the switch that has to be broken off to allow the lever to move one click down from the off position. So to complete what you have:
Switch positions:
J : Stalk pulled down - intermittent; Relates to left-most selection of the contacts.
0 : Wipers off
P: Stalk pulled back - activate short cycle of wipers.
Contact S1:
J : No connection
0 : Ground
1 : Ground
2 : Ground
P : 12v
Spoke
post Jul 31 2022, 06:10 PM
Jerry
QUOTE(bbrock @ Jul 31 2022, 07:09 PM) *
Switch positions:
0 : Wipers off
Contact S1:
J : No connection
0 : Ground
1 : Ground
2 : Ground
P : 12v
@bbrock
OK, so for position P stalk pulled back, does that move these 2 contacts? I wonder if the double horizontal lines broken between the 2 contacts means when the stalk is pulled back.
If so, it looks like you want to connect the washer motor to 53c which looks like it is not wired out. 53c is open unless the stalk is pulled back.
So you had the washer motor connected to S1, correct? Pull back on the stalk and the washer and wipers go. But since the motor is connected from S1 to ground, the motor shows S1 a ground connection thus the J, 0, 1, 2 position of S1 are all ground and the intermittent wipers do not work. Does this sound plausible?
bbrock   Attention Electrical Gurus   Jul 28 2022, 07:17 PM
Spoke   @bbrock Do you have documentation describing the...   Jul 29 2022, 09:20 AM
bbrock   @[url=http://www.914world.com/bbs2/index.php?show...   Jul 29 2022, 10:04 AM
Superhawk996   Instead of the kit, I'm branching off the br...   Jul 31 2022, 01:46 PM
bbrock   Instead of the kit, I'm branching off the b...   Jul 31 2022, 01:51 PM
dr914@autoatlanta.com   intermittent is activated by pulling the stalk dow...   Jul 29 2022, 11:02 AM
FlacaProductions   As George says - but do you have the tab broken ou...   Jul 29 2022, 11:53 AM
bbrock   Let's back up a bit. My intermittent wipers w...   Jul 29 2022, 12:45 PM
lesorubcheek   It's kinda difficult looking at the wiring dia...   Jul 29 2022, 01:45 PM
bbrock   It's kinda difficult looking at the wiring di...   Jul 29 2022, 04:52 PM
lesorubcheek   I know the feeling. You just can't let this go...   Jul 29 2022, 07:47 PM
bbrock   I know the feeling. You just can't let this g...   Jul 29 2022, 10:52 PM
Spoke   I've been following this discussion but haven...   Jul 31 2022, 04:44 PM
bbrock   I've been following this discussion but haven...   Jul 31 2022, 05:09 PM
Spoke   Ah! There is something I should have explai...   Jul 31 2022, 06:10 PM
bbrock   [b]@[url=http://www.914world.com/bbs2/index.php?...   Jul 31 2022, 06:45 PM
Spoke   @bbrock I'm not sure how pulling back on the...   Jul 29 2022, 09:54 PM
bbrock   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Jul 29 2022, 10:40 PM
bbrock   My previous post was incorrect. It was dark in th...   Jul 30 2022, 10:29 AM
Superhawk996   I apologize I'm worthless for this thread. Al...   Jul 30 2022, 10:36 AM
bbrock   I apologize I'm worthless for this thread. A...   Jul 30 2022, 11:20 AM
Superhawk996   I apologize I'm worthless for this thread. ...   Jul 30 2022, 11:38 AM
bbrock   Can you post a more comprehensive circuit diagra...   Jul 30 2022, 12:41 PM
Superhawk996   The circuit is so simple there is really no need...   Jul 30 2022, 01:18 PM
bbrock   The circuit is so simple there is really no nee...   Jul 30 2022, 03:51 PM
Bartlett 914   It has been awhile since I worked with the washer ...   Jul 30 2022, 01:08 PM
bbrock   I went ahead and ordered one of these low voltage ...   Jul 31 2022, 10:16 AM
Superhawk996   I went ahead and ordered one of these low voltage...   Jul 31 2022, 10:27 AM
windforfun   I went ahead and ordered one of these low voltag...   Jul 31 2022, 10:32 AM
bbrock   I went ahead and ordered one of these low voltag...   Jul 31 2022, 11:29 AM
Superhawk996   Here, I added the "complicated" part f...   Jul 31 2022, 11:43 AM
Superhawk996   @bbrock Do you actually have your intermittent r...   Jul 31 2022, 12:50 PM
bbrock   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Jul 31 2022, 01:42 PM
Superhawk996   You're explanation of the grn/wht wire make...   Jul 31 2022, 01:58 PM
bbrock   [quote name='bbrock' post='3019478' date='Jul 31 ...   Jul 31 2022, 02:07 PM
bbrock   No -- that brown / black doesn't get ground t...   Jul 31 2022, 02:26 PM
lesorubcheek   Anyway, the DMM says this. Pull back the lever a...   Jul 31 2022, 02:54 PM
Superhawk996   just saw your other post Yes - the schematics are...   Jul 31 2022, 01:48 PM
bbrock   just saw your other post Yes - the schematics ar...   Jul 31 2022, 01:59 PM
bbrock   And I agree about the confusion. I'm not a fa...   Jul 31 2022, 02:09 PM
Superhawk996   I don't think you'll be able to get the co...   Jul 31 2022, 02:26 PM
bbrock   I don't think you'll be able to get the c...   Jul 31 2022, 02:31 PM
Superhawk996   :idea: Ok now I think I understand your idea bet...   Jul 31 2022, 02:58 PM
bbrock   :idea: Ok now I think I understand your idea be...   Jul 31 2022, 03:47 PM
Superhawk996   Now that I've had some time to think about the...   Jul 31 2022, 04:10 PM
bbrock   Now that I've had some time to think about th...   Jul 31 2022, 04:57 PM
Superhawk996   Don't think that one will work. It switches...   Jul 31 2022, 05:17 PM
Spoke   Now that I've had some time to think about t...   Jul 31 2022, 06:31 PM
bbrock   I think I agree with you about the switching. Th...   Jul 31 2022, 06:56 PM
Spoke   Yes, but the voltage readings are small. In the...   Jul 31 2022, 07:39 PM
bbrock   Yes, but the voltage readings are small. In th...   Jul 31 2022, 08:42 PM
Superhawk996   I shouldn't have called this a "simple...   Aug 1 2022, 06:38 AM
bbrock   I shouldn't have called this a "simple...   Aug 1 2022, 08:39 AM
Superhawk996   I still say we didn't need the full schematic...   Aug 1 2022, 09:03 AM
lesorubcheek   If the goal is to have an open circuit at S on the...   Aug 1 2022, 12:03 PM
Spoke   If the goal is to have an open circuit at S on th...   Aug 1 2022, 05:08 PM
bbrock   [quote name='lesorubcheek' post='3019726' date='A...   Aug 1 2022, 06:18 PM
lesorubcheek   [quote name='lesorubcheek' post='3019726' date='...   Aug 1 2022, 06:34 PM
bbrock   I did . . . just because that is the way I...   Aug 1 2022, 01:40 PM
Superhawk996   Here's the blurb from the 73' owner's ...   Aug 1 2022, 06:53 AM
bbrock   GENIUS! Dug through my spares and found an un...   Aug 1 2022, 06:55 PM
Spoke   Sounds like the intermittent relay needs a couple ...   Aug 2 2022, 03:50 AM
bbrock   Sounds like the intermittent relay needs a couple...   Aug 2 2022, 08:12 AM
Spoke   @bbrock Either BY880 diodes will work. According...   Aug 2 2022, 08:31 AM
bbrock   @[url=http://www.914world.com/bbs2/index.php?show...   Aug 2 2022, 10:55 AM
Superhawk996   Getting close. :trophy:   Aug 2 2022, 08:35 AM
bbrock   Unbelievable! The diodes arrived yesterday. ...   Aug 6 2022, 02:26 PM
bbrock   Well that escalated quickly :blink: The new VDO ...   Aug 13 2022, 07:44 PM
930cabman   [b]Well that escalated quickly :blink: The new ...   Aug 14 2022, 09:30 AM
bbrock   I may be able to piece together an original washe...   Aug 14 2022, 11:32 AM
FlacaProductions   Very cool - and everyone likes a graceful recovery...   Aug 13 2022, 10:29 PM
davep   A very interesting discussion. I have been kicking...   Aug 13 2022, 10:31 PM
bbrock   A very interesting discussion. I have been kickin...   Aug 13 2022, 11:33 PM
Superhawk996   :cool: Bookmarking this thread.   Aug 14 2022, 08:38 AM
- Lo-Fi Version Time is now: 7th April 2025 - 04:15 PM
