Turn Signal indicators, 2 instead of 1 |
John |
Mar 4 2006, 09:36 AM
member? what's a member? Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
Has anyone rewired a later model car to that of an early model car to get individual turn signal indiators?
The early style was wired so that each indicator light (in the tach) had one of the turn signal wires (black/white stripe or black/green stripe) and the blue/white stripe. As far as I can tell, the flasher relay is the same, but the wiring is different due to the fact that the 1974 and later cars only had the single indicator light in the tach. The 74 wiring diagram shows the indicator light wired to the blue/white stripe and ground. Is this rihgt or not. maybe I'll wire it up and find out..... |
nivekdodge |
Aug 6 2022, 10:06 AM
Member Group: Members Posts: 285 Joined: 28-August 21 From: Pittsburgh Pa Member No.: 25,860 Region Association: MidAtlantic Region |
Wow someone else had to do this
Lo-Fi Version | Time is now: 19th January 2025 - 08:15 AM |
