> high idle, 3000rpm idle
slotty008
post Jul 24 2022, 03:29 PM
Hi guys ,
I just hope that someone could help us with the idle of my '75 2.0. I have the car for almost 7 years now and idle was always a little bit too high. We have been trying to correct this but it got worse instead of better. We changed the distributor to a 123 ignition, we changed all the vacuumlines, the AAR has been cleaned out and the idle screw is completely closed.
The car starts at 1600rpm when cold and once it is warm it goes to 3000rpm and the idle stays there. The car pulls very well , a lot better better than when I just had it. (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif)
slotty008
post Aug 9 2022, 12:57 PM
Update: I ordered a throttle body gasket and the rubber to the airfilter. My mechanic installed them today but the problem is not gone. (IMG:style_emoticons/default/headbang.gif) He thinks that the throttle valve is worn( axle and bushings) I suppose throttle bodies are no longer available so is it possible to repair this? (IMG:style_emoticons/default/wacko.gif)
DRPHIL914
post Aug 9 2022, 01:13 PM
Dr. Phil
QUOTE(slotty008 @ Aug 9 2022, 02:57 PM) *
yes they can be rebuild and have new bushings installed, there is a member here that does this service. Phil i believe, he rebuilt my with all new stuff a couple years ago.
Smoke machine would help you find any other leaks, but also with d-jet, if you are running lean you will have a fast idle.
Phil
slotty008   high idle   Jul 24 2022, 03:29 PM
BeatNavy   I'm going to say you have: a. a vacuum line d...   Jul 24 2022, 04:05 PM
porschetub   I'm going to say you have: a. a vacuum line ...   Jul 24 2022, 07:12 PM
Lockwodo   Hi guys , I just hope that someone could help us ...   Jul 24 2022, 04:38 PM
wonkipop   test the AAR after the car has completely warmed (...   Jul 24 2022, 05:00 PM
cgnj   Broken intake gasket. Paid big dollars in the earl...   Jul 24 2022, 05:40 PM
Rand   3k? Definitely a huge vacuum leak. Timing can...   Jul 24 2022, 06:07 PM
emerygt350   Yeah, 3k is way too high for AAR as well. Get you...   Jul 24 2022, 07:09 PM
slotty008   Thank you guys for all the suggestions. I'm go...   Jul 25 2022, 01:01 AM
slotty008   My mechanic picked up the car this morning and thi...   Jul 25 2022, 05:59 AM
emerygt350   My mechanic picked up the car this morning and th...   Jul 25 2022, 06:48 AM
VaccaRabite   Go find my thread on making a home-built smoke mac...   Jul 25 2022, 07:37 AM
dr914@autoatlanta.com   if the thottle is completely closed then you have ...   Jul 25 2022, 09:09 AM
StarBear   :popcorn:   Jul 25 2022, 09:27 AM
Rand   George chimed in with nothing that wasn't alre...   Jul 26 2022, 04:16 PM
slotty008   Update, This afternoon I got a call from my mechan...   Jul 29 2022, 01:38 PM
StarBear   AARs are available. One sold here just a few days ...   Jul 29 2022, 04:52 PM
Lockwodo   AARs are available. One sold here just a few days...   Jul 29 2022, 05:14 PM
slotty008   AARs are available. One sold here just a few day...   Jul 30 2022, 02:05 AM
wonkipop   [quote name='StarBear' post='3019035' date='Jul ...   Jul 30 2022, 02:55 AM
wonkipop   AARs are available. One sold here just a few days...   Jul 29 2022, 08:26 PM
brant   Sounds like he suspects the bushings holding the b...   Jul 29 2022, 05:23 PM
StarBear   Ahhh. Didn’t pick up on that. Thanks!   Jul 29 2022, 10:14 PM
slotty008   Update: I ordered a throttle body gasket and the r...   Aug 9 2022, 12:57 PM
DRPHIL914   Update: I ordered a throttle body gasket and the ...   Aug 9 2022, 01:13 PM
rjames   Throttle body is likely worn to some degree (they ...   Aug 9 2022, 01:33 PM
slotty008   Update: By the end of August we finally had some r...   Oct 31 2022, 08:37 AM
76-914   Update: By the end of August we finally had some ...   Oct 31 2022, 09:03 AM
Dave_Darling   BTW, do all 914's have the same throttle body...   Oct 31 2022, 07:03 PM
wonkipop   BTW, do all 914's have the same throttle bod...   Nov 1 2022, 04:23 AM
slotty008   BTW, do all 914's have the same throttle bod...   Nov 1 2022, 04:39 AM
slotty008   Now that I'm retired, I've finally found t...   Mar 18 2023, 04:55 AM
slotty008   RE: high idle   Mar 18 2023, 04:57 AM
VaccaRabite   Mine leaked at the same place. Ended up replacing ...   Mar 18 2023, 08:59 AM
76-914   Those can be re-bushed. Is there such a word? Any ...   Mar 18 2023, 09:12 AM
rjames   Those can be re-bushed. Is there such a word? Any...   Mar 24 2024, 11:17 AM
emerygt350   On my car the idle screw even leaks when fully clo...   Mar 18 2023, 04:21 PM
slotty008   After disassembling the AAR several times, I gave ...   Mar 24 2024, 09:23 AM
slotty008   Here it is installed.   Mar 24 2024, 09:25 AM
slotty008   I've put a box on it to protect it. The bottom...   Mar 24 2024, 09:28 AM
slotty008   And this is the knob in the cockpit.   Mar 24 2024, 09:33 AM
emerygt350   And this is the knob in the cockpit. I like it...   Mar 24 2024, 02:59 PM
rhodyguy   Do not overlook the stacked elbow. Kind of an obsc...   Mar 25 2024, 11:18 AM
20 User(s) are reading this topic (20 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 21st December 2024 - 10:13 AM
