Van B |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,614 Joined: 20-October 21 From: Maryland Member No.: 26,011 Region Association: None ![]() ![]() |
Evening 914 World!
I’ve been gathering parts over the past few months and have finally reached critical mass. So, let the project thread begin! After working on the FI through the winter, I’m satisfied that the engine remains in good health with it’s original 53k miles. However, the rubber and plastic holding everything together is a different story. Which brings me to the scope and objective of this project. In short, I am looking for what I will call, “Improved Original”. What the phrase means to me is that I want to maintain the character and feel of the original car, but still take advantage of any and all modern improvements that will either, improve reliability, safety, operability, or any combination there of. This will include a suspension and chassis rebuild, power train reseal and refinishing, brake system rebuild, and fuel system overhaul. When I’m done, I want to have a car that drives like it’s nearly new, but doesn’t look over restored. Because the car is a survivor, I think it’s important to keep the stories and history of the car intact. Finally, I’d like to post my thanks to the community and vendors that make it possible to enjoy this hobby. Stay tuned! Van Attached thumbnail(s) ![]() |
Van B |
You only need to loosen it enough to slip the mount and long bolt out of the channel on the transmission support bracket. Remove the two bolts/nuts holding the mount to the chassis, loosen the long bolt from the mount to the transmission and take out the whole thing. Then install the same way.
StarBear |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,950 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States ![]() ![]() |
You only need to loosen it enough to slip the mount and long bolt out of the channel on the transmission support bracket. Remove the two bolts/nuts holding the mount to the chassis, loosen the long bolt from the mount to the transmission and take out the whole thing. Then install the same way. Ah, but I think (?) the problem is that there's no headroom to slip the center bolt up that far - only an inch, tops. Mine looks like the pic below, from another current thread. ![]() Haven't planned to hijack your build thread out of confusion and need, Van, so I apologize. Yes, @wonkipop - but I'm not planning to do that anytime soon. Needs to be done (120k mi), but not urgent though may be the source of the little hum/vibration I get in 4th/5th gear on the highway, hence the idea to replace the mounts as perhaps a faster/cheaper solution attempt as they're the original mounts. |
Lo-Fi Version | Time is now: 25th June 2024 - 10:00 PM |
