> How to inspect the underside and longs without a lift, now the Not another novice project thread
seanpaulmc
post Dec 25 2016, 04:26 PM
I've just purchased a '73 914 and owned it long enough to ship it to Orlando and take it to go get titled. With only having it for this short period my list of concerns is growing. I have no intentions of driving the car around until I can assess how rusty it is. I appreciate the support and responses to the questions about transportation and engine identification. This is a superb community.
What advice do you have for lifting the car to inspect underneath and such without having access to a lift? I have read some of the build threads on here and you guys have some amazing shops and do incredible work! ...one day. But, at this point I don't have that.
For now I'd like to lift the car, take the wheels off, and take the longitudinal covers off to get a good look at the structural areas of the car. However, I have concerns because this is a snowbelt car and I've read the stories about putting a floor jack through a rusted out car. Where should I lift with the floor jack (trust the jacking points?, other areas) and where should I put the jack stands so that I can poke around some and get pictures?
Merry Christmas!!!
Dave_Darling
post Aug 22 2022, 05:22 PM
914 Idiot
Double-check the roll pin on your pedal cluster that holds the clutch pedal onto the cross-shaft. Earlier versions of the bronze bushing kit used a standard roll pin that is not up to the job in the longer term. The original pin is a spiral pin that has a lot more meat and is tougher. I think I have heard that newer bronze bushing kits also come with spiral pins, but I'm not sure--and it's worth taking a minute to check.
--DD
seanpaulmc   How to inspect the underside and longs without a lift   Dec 25 2016, 04:26 PM
Rand   Don't worry about lifts and jacks yet. Just st...   Dec 25 2016, 04:34 PM
mepstein   Start cleaning the trunks and interior of your car...   Dec 25 2016, 04:59 PM
branston   I don't jack my '74 under the body, I tend...   Dec 25 2016, 10:01 PM
seanpaulmc   I finally got some time and pulled the covers off ...   Jan 31 2017, 05:01 PM
Dave_Darling   A 2x4 can distribute the load from the jack across...   Jan 31 2017, 05:39 PM
JoeDees   You're gonna need to buy a welder.   Jan 31 2017, 05:11 PM
r_towle   You're gonna need to buy a welder. Yup   May 8 2022, 07:06 PM
mepstein   You need long and floor pan repair. Once you scrap...   Jan 31 2017, 05:16 PM
seanpaulmc   Thanks for the feedback, All. About that welder...   Feb 1 2017, 04:49 PM
DennisV   About that welder, is there advice for a recommen...   Aug 27 2023, 04:15 PM
Ferg   Whats the code for the original color on this car?...   Feb 1 2017, 04:57 PM
seanpaulmc   L96M Original is a light blue metallic. Current...   Feb 1 2017, 05:35 PM
Ferg   L96M Original is a light blue metallic. Curren...   Feb 1 2017, 05:47 PM
amfab   Your longs and pans look like they have similar is...   Feb 1 2017, 05:52 PM
JoeDees   There will be a lot of opinions on the welder (and...   Feb 1 2017, 06:06 PM
branston   There will be a lot of opinions on the welder (an...   Apr 1 2017, 07:32 PM
PanelBilly   There's some smart people with the skills to h...   Feb 1 2017, 07:29 PM
mepstein   How about the hell hole? You can see the suspensi...   Feb 1 2017, 08:03 PM
Larmo63   You should assess everything under the tar padding...   Feb 1 2017, 08:10 PM
seanpaulmc   Here's the initial look underneath. I'm p...   Apr 1 2017, 06:52 PM
Dave_Darling   The engine cradle is cockeyed (i.e. not vertical)...   Apr 2 2017, 01:16 PM
Robarabian   Duplicate post. Sorry. Here's the initial lo...   Mar 3 2021, 10:33 PM
branston   If your webbing doesn't clean up or the retr...   Apr 2 2017, 01:42 PM
boxsterfan   You are definitely going to need to order from the...   Apr 2 2017, 02:26 PM
seanpaulmc   You are definitely going to need to order from th...   Mar 3 2021, 07:11 PM
930cabman   Time, patience, basic skills, repeat, repeat and d...   Mar 3 2021, 07:24 PM
seanpaulmc   Hard to believe this tread was stared four years a...   Mar 3 2021, 07:30 PM
seanpaulmc   Let's see what we're working with. Or, wi...   Mar 3 2021, 07:55 PM
seanpaulmc   5/8/22 - might as well make it a project thread. ...   May 8 2022, 05:30 PM
seanpaulmc   I'm using 18 gage gavaneal and a lot of self t...   May 8 2022, 05:41 PM
seanpaulmc   Links to threads on some of the other repairs: :t...   May 8 2022, 05:50 PM
seanpaulmc   Starting to patch the firewall. Using those c...   May 8 2022, 06:06 PM
seanpaulmc   Passenger Jack Point repair: Peeing back the ...   May 8 2022, 06:33 PM
930cabman   Great looking work, keep your focus and she will b...   May 9 2022, 07:06 AM
seanpaulmc   Been a while for an update. With it raining like i...   Aug 14 2022, 02:43 PM
seanpaulmc   Now that I've cut my teeth on the Hell hole re...   Aug 14 2022, 03:01 PM
seanpaulmc   Clearly the plan was to work on getting the new fl...   Aug 14 2022, 03:21 PM
seanpaulmc   And, for a change of pace worked on something else...   Aug 14 2022, 03:27 PM
Puebloswatcop   Hey, things are looking good so far. as for the c...   Aug 14 2022, 05:33 PM
seanpaulmc   Working on the passenger side floor fit up. :saw...   Aug 22 2022, 03:33 PM
DRPHIL914   good work! keep on trucking! great you are...   Aug 22 2022, 04:28 PM
Dave_Darling   Double-check the roll pin on your pedal cluster th...   Aug 22 2022, 05:22 PM
seanpaulmc   Double-check the roll pin on your pedal cluster t...   Aug 22 2022, 05:26 PM
930cabman   Great progress and all this while working on your ...   Aug 23 2022, 08:37 AM
seanpaulmc   For a Safe, Quick, and simple way to remove the sp...   Aug 26 2022, 08:09 AM
seanpaulmc   Working towards installation of the passenger side...   Aug 26 2022, 08:24 AM
930cabman   From what I know it was coated with cosmoline when...   Aug 26 2022, 04:51 PM
seanpaulmc   Well it’s been a while. Where was I? Right, a ...   Feb 21 2023, 06:57 PM
bajafreaks   Well it’s been a while. Where was I? Right, a...   May 29 2023, 08:06 AM
Cairo94507   Great work and progress. :beer2:   Feb 22 2023, 08:25 AM
seanpaulmc   Looking for some pictures of how this section at t...   Feb 23 2023, 09:15 AM
930cabman   Quality of workmanship looks great, keep it going ...   Feb 23 2023, 10:13 AM
seanpaulmc   Quality of workmanship looks great, keep it going...   Feb 23 2023, 10:40 AM
930cabman   Quality of workmanship looks great, keep it goin...   Feb 23 2023, 11:26 AM
Cairo94507   Here is the best shot I have of my car when we wer...   Feb 23 2023, 10:18 AM
Root_Werks   Marc and I used a Borescope camera to inspect insi...   Feb 23 2023, 10:36 AM
seanpaulmc   Today… …all day. :headbang: Remarkably...   Feb 25 2023, 06:54 PM
seanpaulmc   Another patch panel. :welder: Passenger footwel...   Mar 11 2023, 07:43 PM
seanpaulmc   Moved on to peeling back the rusty onion of the A-...   Mar 11 2023, 07:53 PM
seanpaulmc   Really for the first time I feel like I am making ...   Apr 20 2023, 12:32 PM
930cabman   Lookin good, keep on truckin and you will be motor...   Apr 20 2023, 01:25 PM
seanpaulmc   Mmmmmm parts! Had to share my excitement.   Apr 26 2023, 04:14 PM
East coaster   Good metal work. I just did some of those same spo...   Apr 26 2023, 08:01 PM
seanpaulmc   Been a while for an update… floors are done. At...   May 27 2023, 05:20 PM
mgarrison   Been a while for an update… floors are done. A...   May 27 2023, 07:20 PM
Dave_Darling   Herculiner? Make sure you don't get it on you...   May 27 2023, 05:41 PM
East coaster   Just sprayed my tub with Custom Coat bedliner (fro...   May 28 2023, 05:18 AM
seanpaulmc   Thanks for the references on the bed / raptor line...   May 28 2023, 09:12 AM
seanpaulmc   @bajafreaks The passenger floor pan I bought fro...   May 29 2023, 01:45 PM
bajafreaks   @[url=http://www.914world.com/bbs2/index.php?show...   May 29 2023, 06:09 PM
seanpaulmc   For review, we last left off with completion of th...   Jul 6 2023, 01:27 PM
930cabman   Great progress, currently I am repairing some mino...   Jul 6 2023, 02:23 PM
seanpaulmc   Back at it. I made up my own replacement corner...   Aug 27 2023, 03:29 PM
bkrantz   Back at it. I made up my own replacement corne...   Jul 17 2024, 07:24 PM
seanpaulmc   Back at it. I made up my own replacement corn...   Jul 23 2024, 12:08 PM
seanpaulmc   With a little help from you guys I was able to fig...   Sep 2 2023, 07:29 PM
930cabman   +1 with your progress, all the while working outdo...   Sep 3 2023, 05:51 AM
seanpaulmc   Put back the old door sill. Mostly. Almost done ...   Sep 9 2023, 06:14 PM
seanpaulmc   Sometimes a project reaches a tipping point… ...   Jul 7 2024, 07:17 PM
Artfrombama   Impressed with your work and tenacity. Keep up th...   Jul 8 2024, 09:24 PM
seanpaulmc   Between the rain (daily), family life, and regular...   Jul 17 2024, 08:04 AM
seanpaulmc   Kind of a wash out last week when outside of day j...   Jul 23 2024, 12:21 PM
friethmiller   Good job! :trophy: Glad to know I'm not...   Jul 23 2024, 01:55 PM
seanpaulmc   Good job! :trophy: Glad to know I'm no...   Jul 23 2024, 06:51 PM
friethmiller   [quote name='friethmiller' post='3158074' date='J...   Jul 24 2024, 06:37 AM
930cabman   [quote name='friethmiller' post='3158074' date='...   Jul 24 2024, 01:29 PM
seanpaulmc   Rain delay today. Workshop closed. But yesterday ...   Jul 25 2024, 06:00 PM
seanpaulmc   Roll over jig I did not come up with this but cou...   Jul 26 2024, 07:19 PM
seanpaulmc   What’s behind your seam sealer? :angry:   Jul 27 2024, 07:21 PM
seanpaulmc   Looking to the weekend ahead and hoping to put in ...   Aug 27 2024, 09:27 AM
Geezer914   That's what I did, coated the underside with t...   Aug 27 2024, 11:37 AM
friethmiller   [Not trying to hijack the thread here with my pics...   Aug 27 2024, 12:22 PM
seanpaulmc   [Not trying to hijack the thread here with my pic...   Aug 27 2024, 12:50 PM
friethmiller   So true about being outside! Part of any rest...   Aug 27 2024, 01:26 PM
seanpaulmc   Need a waterproof car cover. Thought this was fine...   Aug 31 2024, 06:24 PM
seanpaulmc   Hot! No rain today. Welding could be done. :...   Aug 31 2024, 06:31 PM
930cabman   Hot! No rain today. Welding could be done. ...   Sep 1 2024, 05:22 AM
seanpaulmc   Hot! No rain today. Welding could be done. ...   Sep 1 2024, 01:56 PM
seanpaulmc   Got the rest of it in just before the heavens brok...   Sep 1 2024, 02:01 PM
- Lo-Fi Version Time is now: 28th November 2024 - 06:34 AM
