TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,330 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
914 locks. com is now making keys by code
If you don't have the code, l can make a key by the wafer sequence Price is $65.00 and includes a black oem key. Extra cut keys (including red valet keys) are available at $45.00 each. Generic cut keys are $15.00 each. Blank oem keys are $30.00 each Contact me at cbntmkr at (@) gmail.com for more info. |
bbrock |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains ![]() ![]() |
If you have a door or ignition tumbler out, you can get your code by reading the wafer numbers from shoulder to tip. The numbers are stamped on the wafers. There is a great technical article on re-keying locks here. And here is a thread discussing reading the code. It worked for me.
The reason you can't use trunk or glove box keys to get the code is because they will have a valet wafer randomly placed somewhere in the cylinder which will leave you with a missing digit on your code. BTW, Curt's service is a screaming deal compared to what I spent buying genuine key blanks from Porsche and having a local locksmith cut them by code. |
TheCabinetmaker |
If you have a door or ignition tumbler out, you can get your code by reading the wafer numbers from shoulder to tip. The numbers are stamped on the wafers. There is a great technical article on re-keying locks here. And here is a thread discussing reading the code. It worked for me. The reason you can't use trunk or glove box keys to get the code is because they will have a valet wafer randomly placed somewhere in the cylinder which will leave you with a missing digit on your code. BTW, Curt's service is a screaming deal compared to what I spent buying genuine key blanks from Porsche and having a local locksmith cut them by code. The valet wafer replaces the # 2 wafer, so the code can be found that way. Not all wafers are stamped. I measure every wafer to make sure it's in tolerance with factory wafer sizes. |
Lo-Fi Version | Time is now: 12th March 2025 - 05:19 AM |
