Brakes don't Bite |
Brakes don't Bite |
bkrantz |
Sep 1 2022, 08:16 PM
914 Guru Group: Members Posts: 8,170 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
As part of my rebuild I completely replaced the brake system:
calipers and rear pressure valve rebuilt by PMB new ATE 19mm master cylinder new hard and flex lines new disks and Porterfield R4-S pads I went through many (many!) episodes of bleeding, with different methods. The pedal feels very firm from the first push, and does not pump up. Rear clearance is set at .004". I went through the PMB bedding process, and have driven around a bit. But the braking force seems weak. When I get on the brake pedal, I do not feel any "bite". Another 914 friend drove the car and also agrees. Any suggestions? |
mgphoto |
Sep 1 2022, 09:54 PM
"If there is a mistake it will find me" Group: Members Posts: 1,366 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
19mm master cylinder, push the pedal harder, they will bite.
Lo-Fi Version | Time is now: 19th December 2024 - 12:56 AM |
