Brakes don't Bite |
Brakes don't Bite |
bkrantz |
Sep 1 2022, 08:16 PM
914 Guru Group: Members Posts: 8,170 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
As part of my rebuild I completely replaced the brake system:
calipers and rear pressure valve rebuilt by PMB new ATE 19mm master cylinder new hard and flex lines new disks and Porterfield R4-S pads I went through many (many!) episodes of bleeding, with different methods. The pedal feels very firm from the first push, and does not pump up. Rear clearance is set at .004". I went through the PMB bedding process, and have driven around a bit. But the braking force seems weak. When I get on the brake pedal, I do not feel any "bite". Another 914 friend drove the car and also agrees. Any suggestions? |
JamesM |
Sep 2 2022, 09:27 AM
Advanced Member Group: Members Posts: 2,013 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
As part of my rebuild I completely replaced the brake system: calipers and rear pressure valve rebuilt by PMB new ATE 19mm master cylinder new hard and flex lines new disks and Porterfield R4-S pads I went through many (many!) episodes of bleeding, with different methods. The pedal feels very firm from the first push, and does not pump up. Rear clearance is set at .004". I went through the PMB bedding process, and have driven around a bit. But the braking force seems weak. When I get on the brake pedal, I do not feel any "bite". Another 914 friend drove the car and also agrees. Any suggestions? Can you lock the brakes up if you stand on them? If yes then they are working. Pad type can change the feel of the initial "bite" however I find that the rebuilt calipers feel a little soft at first but will become more responsive over time as the new rubber in them work hardens. I find going REALLY aggressive with the bedding procedure helps with this as well. You really want to cook those things. |
Superhawk996 |
Sep 2 2022, 09:31 AM
914 Guru Group: Members Posts: 6,588 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Can you lock the brakes up if you stand on them? (IMG:style_emoticons/default/agree.gif) This question needs to be answered. If the front brakes can’t be locked there is something wrong. |
Lo-Fi Version | Time is now: 19th December 2024 - 01:06 AM |
