> Model Specific Information
> Oil Breather Cover Lid, 901.107.701.3R
DennisV
post Sep 4 2022, 06:23 PM
Is this a correct Oil Cover Lid for a 1970 914-6? It appears to have a threaded port for a temperature or pressure sensor / switch. I can't find that part number in the 914 or early 911 parts catalogs.
901.107.701.3R
johnhora
post Sep 5 2022, 08:39 AM
914-6 intake manifold with vacuum ports
picture from the shop manuals 914-6 fuel system volume
DennisV
post Sep 9 2022, 10:09 AM
QUOTE(johnhora @ Sep 5 2022, 07:39 AM) *
Very interesting! Thanks for the visual aids. Do you know if those ports were threaded?
Our engine was missing the carbs. What we have now is a set of Zenith. The intake manifold has openings, but they are are not threaded.
DennisV   Oil Breather Cover Lid   Sep 4 2022, 06:23 PM
rgalla9146   Is this a correct Oil Cover Lid for a 1970 914-6?...   Sep 5 2022, 05:59 AM
nditiz1   I thought all 6s were carbd which would mean no TP...   Sep 5 2022, 06:36 AM
SixerJ   My -6 engine which happens to be on the floor at t...   Sep 5 2022, 07:50 AM
johnhora   The "TPS" was used as an early emissions...   Sep 5 2022, 08:10 AM
rgalla9146   Original equipment on our cars was a temp sensor ...   Sep 5 2022, 08:18 AM
johnhora   914-6 Throttle Valve Positioner....the vacuum ...   Sep 5 2022, 08:33 AM
johnhora   914-6 intake manifold with vacuum ports pictur...   Sep 5 2022, 08:39 AM
DennisV   914-6 intake manifold with vacuum ports Very int...   Sep 9 2022, 10:09 AM
rgalla9146   [quote name='johnhora' post='3027284' date='Sep 5...   Sep 9 2022, 01:49 PM
DennisV   Dennis those carbs and manifolds are from a ...   Sep 9 2022, 04:12 PM
DennisV   Dennis those carbs and manifolds are from a ...   May 29 2024, 10:14 AM
davep   You are confusing casting numbers with part #...   Sep 5 2022, 08:43 AM
rgalla9146   Holy Cow Visual aids aplenty   Sep 5 2022, 01:10 PM
sixnotfour   TVP was annoying, pull up to stop light with high ...   Sep 9 2022, 10:57 AM
fixer34   Had me curious so I went to look. March '70. ...   Sep 9 2022, 12:20 PM
fixer34   I have wondered for a while what the sensor was th...   Sep 9 2022, 12:27 PM
rgalla9146   I think that switch (two wire) was the trigger for...   Sep 9 2022, 01:30 PM
- Lo-Fi Version Time is now: 3rd April 2025 - 01:48 AM
