Any harm to vintage engines running unleaded fuels. |
914043 |
Sep 9 2022, 02:46 PM
Member Group: Members Posts: 93 Joined: 2-April 19 From: California Member No.: 23,007 Region Association: Central California |
Back in the day when they took lead out of gas there was a lot of concern that without the cushioning effect the lead had on the valve face there would be bent and broken valves. Since my car fits those criteria and will be driving soon what if any concerns should I be aware of?? Fairly technical but Thanks for any help that might save me a damaged engine. Best to Ya
Van B |
Sep 10 2022, 08:33 PM
Senior Member Group: Members Posts: 1,618 Joined: 20-October 21 From: WR, GA Member No.: 26,011 Region Association: None |
As @Superhawk996 described, you can rest assured that if you have aluminum heads, you’ll be fine with unleaded. But, until anti-knock sensors came around you did have to pay attention to the minimum octane rating. In the US we use the (RON+MON)/2 with motor octane being a lower number than research octane, you won’t see our fuel numbers matching the RON only number, but the measure I’ve always used is to add 5 to the number at the pump to know if it’s high enough octane for you engine’s listing in RON. For example, 91 RON means you can run 87 octane from a US pump.
@wonkipop I think the heads may have been different due to runner configuration for the carbs. |
wonkipop |
Sep 10 2022, 08:37 PM
Advanced Member Group: Members Posts: 4,670 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
[/quote] i thought that too ------- to start with. but i fully investigated it. there was a small inlet casting that bolted up to the same studs and casting area that the fuel injector/air inlet manifolds bolted up to. the inlet casting transitioned the single barrel carb on each side into two inlet tracts into the head. so i don't think it was that. |
Lo-Fi Version | Time is now: 6th January 2025 - 07:31 PM |
