> Any harm to vintage engines running unleaded fuels.
914043
post Sep 9 2022, 02:46 PM
Back in the day when they took lead out of gas there was a lot of concern that without the cushioning effect the lead had on the valve face there would be bent and broken valves. Since my car fits those criteria and will be driving soon what if any concerns should I be aware of?? Fairly technical but Thanks for any help that might save me a damaged engine. Best to Ya
bbrock
post Sep 10 2022, 12:17 PM
Here's a rule of thumb Octane/compression chart. FWIW, I'm theoretically running 8.2:1 compression as calculated by deck height (haven't measured directly) and it run fine on regular gas. I do run at high altitude though which requires less octane. I might have to bump to mid-grade if I ever drive down out of the mountains.
And just to complicate more, ethanol blend has more oxygen than pure gasoline so runs a little leaner.
Dave_Darling
post Sep 11 2022, 07:13 PM
914 Idiot
QUOTE(bbrock @ Sep 10 2022, 11:17 AM) *
Here's a rule of thumb Octane/compression chart...
Note that our engines do not follow this chart very well. The combustion chamber shape, mixture and timing control, and cooling that we have generally means we suffer detonation earlier than more modern engines do.
In stock form, the 2.0 and 1.8 engines take regular-grade fuel. The 1.7 engines (except for the low-compression California-only 73 1.7) take super-grade. The European-spec 2.0 (8.0:1 compression) takes mid-grade, and the European-spec 1.8 (8.5:1) takes super-grade.
--DD
914043   Any harm to vintage engines running unleaded fuels.   Sep 9 2022, 02:46 PM
bbrock   All 914 engines use hardened valve seats so no pro...   Sep 9 2022, 03:06 PM
914043   All 914 engines use hardened valve seats so no pr...   Sep 9 2022, 05:39 PM
wonkipop   All 914 engines use hardened valve seats so no p...   Sep 9 2022, 09:29 PM
StarBear   I don’t know why but my 1.8 seems to run a bit s...   Sep 9 2022, 04:04 PM
930cabman   As I recall lead formerly in pump gas was also a l...   Sep 9 2022, 04:29 PM
bbrock   From what I have read, all Porsche engines since a...   Sep 10 2022, 09:17 AM
bbrock   BTW, I've also read that all aluminum heads us...   Sep 10 2022, 09:22 AM
Superhawk996   BTW, I've also read that all aluminum heads u...   Sep 10 2022, 10:14 AM
wonkipop   BTW, I've also read that all aluminum heads ...   Sep 10 2022, 04:33 PM
914043   Two more thoughts, one I faintly remember sodium f...   Sep 10 2022, 10:42 AM
Superhawk996   Two more thoughts, one I faintly remember sodium ...   Sep 10 2022, 10:49 AM
Mikey914   The greatest harm to the engine is from fire. The ...   Sep 10 2022, 10:44 AM
Mikey914   Our engines don't really benefit from the high...   Sep 10 2022, 11:03 AM
bbrock   Here's a rule of thumb Octane/compression char...   Sep 10 2022, 12:17 PM
Dave_Darling   Here's a rule of thumb Octane/compression cha...   Sep 11 2022, 07:13 PM
second wind   So this is a very interesting topic....would putti...   Sep 10 2022, 05:14 PM
wonkipop   So this is a very interesting topic....would putt...   Sep 10 2022, 05:31 PM
bbrock   So this is a very interesting topic....would put...   Sep 10 2022, 06:14 PM
wonkipop   [quote name='second wind' post='3028558' date='S...   Sep 10 2022, 07:14 PM
bbrock   AN engine (euro 1.8) more highly strung (if you c...   Sep 10 2022, 10:16 PM
Van B   As @Superhawk996 described, you can rest assured...   Sep 10 2022, 08:33 PM
wonkipop   @[url=http://www.914world.com/bbs2/index.php?showu...   Sep 10 2022, 08:37 PM
- Lo-Fi Version Time is now: 6th January 2025 - 07:16 PM
