> Brakes don't Bite
bkrantz
post Sep 1 2022, 08:16 PM
As part of my rebuild I completely replaced the brake system:
calipers and rear pressure valve rebuilt by PMB
new ATE 19mm master cylinder
new hard and flex lines
new disks and Porterfield R4-S pads
I went through many (many!) episodes of bleeding, with different methods. The pedal feels very firm from the first push, and does not pump up. Rear clearance is set at .004". I went through the PMB bedding process, and have driven around a bit.
But the braking force seems weak. When I get on the brake pedal, I do not feel any "bite". Another 914 friend drove the car and also agrees.
Any suggestions?
bkrantz
post Sep 15 2022, 07:48 PM
I replaced the pads with "stock" Textars, front and rear. I had to enlarge one hole in the rear pad backing plates.
I took a first drive today, starting with some gentle braking, and then cruising with light dragging for a while. I then went through a series of repeated moderate to hard braking, first a few times from 40 to 10, then 50 to 10, and finally 60 to 10.
My initial impression is that the Textar pads have more grab, but at the end of the session I could not get the brakes to lock up.
bkrantz   Brakes don't Bite   Sep 1 2022, 08:16 PM
Superhawk996   Brake feel is highly subjective. The obvious thi...   Sep 1 2022, 08:51 PM
mgphoto   19mm master cylinder, push the pedal harder, they ...   Sep 1 2022, 09:54 PM
barnfind9141972   I did the same thing and also couldn’t get much ...   Sep 1 2022, 10:27 PM
Mikey914   The system is notorious for holding bubbles. You w...   Sep 1 2022, 11:07 PM
ChrisFoley   As part of my rebuild I completely replaced the b...   Sep 2 2022, 07:55 AM
Superhawk996   Adjust the rear brake regulator to begin regulat...   Sep 2 2022, 09:24 AM
ChrisFoley   [quote name='ChrisFoley' post='3026647' date='Sep...   Sep 2 2022, 10:58 AM
Superhawk996   [quote name='Superhawk996' post='3026665' date='S...   Sep 2 2022, 11:17 AM
Superhawk996   Add a master cylinder brace to prevent floorboar...   Sep 2 2022, 09:28 AM
JamesM   As part of my rebuild I completely replaced the b...   Sep 2 2022, 09:27 AM
Superhawk996   Can you lock the brakes up if you stand on them? ...   Sep 2 2022, 09:31 AM
jim_hoyland   What MPH would the front lock-up test best be done...   Sep 2 2022, 09:57 AM
Superhawk996   What MPH would the front lock-up test best be don...   Sep 2 2022, 10:06 AM
emerygt350   I just went and tried Locking them up tonight (hav...   Sep 2 2022, 06:32 PM
bkrantz   Thanks for all the replies. Yes, I can lock up th...   Sep 2 2022, 07:38 PM
Superhawk996   But I still think I should feel more bite and urg...   Sep 2 2022, 08:41 PM
JamesM   Thanks for all the replies. Yes, I can lock up t...   Sep 3 2022, 12:44 AM
Van B   I love the motive pressure bleeder. I don’t kno...   Sep 2 2022, 08:23 PM
bbrock   I have essentially the same setup as you and get r...   Sep 2 2022, 08:26 PM
iankarr   It takes several bleeds to get air out of a totall...   Sep 2 2022, 10:34 PM
Geezer914   Pressure bleeding is the best way to bleed the Bra...   Sep 3 2022, 05:20 AM
jim_hoyland   Pressure bleeding is the best way to bleed the Br...   Sep 3 2022, 06:23 AM
gereed75   Different car but maybe a useful data point - I ha...   Sep 3 2022, 09:51 AM
Superhawk996   Not sure what type of compound the R4S is, but ...   Sep 3 2022, 10:07 AM
bbrock   FYI - get ready for things to get worse. Copper...   Sep 3 2022, 11:12 AM
930cabman   FYI - get ready for things to get worse. Coppe...   Sep 9 2022, 01:16 PM
bbrock   Sounds as though the consensus is having the abil...   Sep 9 2022, 03:16 PM
Superhawk996   It was the early version of ABS @Superhawk995 :...   Sep 9 2022, 04:47 PM
PatMc   [quote name='bbrock' post='3026923' date='Sep 3 2...   Sep 15 2022, 10:06 PM
jim_hoyland   What's a recommended for light daily driving ?...   Sep 3 2022, 12:25 PM
JamesM   What's a recommended for light daily driving ...   Sep 3 2022, 12:49 PM
bkrantz   Thanks, again. I will try bedding again with some...   Sep 3 2022, 08:09 PM
michael7810   Thanks, again. I will try bedding again with som...   Sep 4 2022, 06:36 AM
ChrisFoley   I used to sell KFP pads because I liked their perf...   Sep 4 2022, 05:02 AM
bkrantz   I ordered a set of Textar OEM style pads for F and...   Sep 5 2022, 07:57 PM
jim_hoyland   I just ordered the Pagids from PMB, Here’s the i...   Sep 5 2022, 08:46 PM
Montreal914   Mentioned before but the stock system was designed...   Sep 5 2022, 09:12 PM
robkammer   This is a thread I thought I would need to start. ...   Sep 8 2022, 01:25 PM
ChrisFoley   venting clearance of 3mm. Hmm, what?   Sep 8 2022, 03:17 PM
Superhawk996   On my last spirited drive with lots of hard braki...   Sep 8 2022, 03:50 PM
robkammer   Guys: Oops, not 3mm, .003". Clearance between...   Sep 9 2022, 07:39 AM
bbrock   Hmm. I have PMB plated calipers that I rebuild my...   Sep 9 2022, 08:12 AM
robkammer   Thanks All: Good comments all around. Still not su...   Sep 9 2022, 01:14 PM
bkrantz   I replaced the pads with "stock" Textars...   Sep 15 2022, 07:48 PM
robkammer   All: This is all great info. So, an update, last S...   Sep 16 2022, 04:11 PM
bbrock   All: This is all great info. So, an update, last ...   Sep 16 2022, 06:41 PM
Superhawk996   Going on two years and getting tired of screwing ...   Sep 17 2022, 11:05 AM
michael7810   For $35 you can try a set of Textar pads for ...   Sep 16 2022, 04:25 PM
ChrisFoley   New caliper seals cause a long pedal which will pu...   Sep 17 2022, 07:02 AM
PatMc   I would try a conventional bleeding method…one p...   Sep 17 2022, 07:47 AM
robkammer   Thanks All! Have not checked the pedal box, bu...   Sep 17 2022, 01:32 PM
Literati914   Man this is frustrating, hate that you’ve not go...   Sep 19 2022, 09:20 AM
Superhawk996   Man this is frustrating, hate that you’ve not g...   Sep 19 2022, 09:48 AM
rfinegan   Last week I rebuild all 4 calipers, Potterfield pa...   Sep 19 2022, 10:08 AM
scott_in_nh   I very recently got around to installing the KFP 1...   Sep 21 2022, 12:48 PM
bbrock   I do notice they are getting better, but my quest...   Sep 21 2022, 01:44 PM
NARP74   The numbers are on the round barrel, mostly on the...   Sep 21 2022, 01:59 PM
NARP74   For the pedal box flex, I had someone press the pe...   Sep 21 2022, 02:04 PM
- Lo-Fi Version Time is now: 10th March 2025 - 11:41 PM
