WTB partial 75 2.0 wiring harness / ignition, Need uncut wires for ignition etc. |
Graydingo |
Sep 16 2022, 06:37 AM
Member Group: Members Posts: 57 Joined: 12-August 22 From: Las Vegas Member No.: 26,768 Region Association: Southwest Region |
Previous owner went nuts in my 75 2.0 ignition harness cutting all the wires that plug into the key/ignition. So I'm looking for the 6 wires complete, full length coming out of the black plastic plug that plugs into the back of the column ignition switch.
I also need this yellow with red stripe wire complete that seems to run the length of the harness. I'd like soft pliable wires and will consider full used OEM harnesses for the right price. Thanks in advance! Duane |
914Sixer |
Sep 18 2022, 11:04 AM
914 Guru Group: Members Posts: 9,051 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
This is what i found. Has about 2 ft of wire. Think I saw a couple feet of the yellow with red stripe. Not seeing yellow wire coming out of your harness, was it cut off?
Attached image(s) |
Lo-Fi Version | Time is now: 22nd January 2025 - 02:56 PM |
