> ECU part numbers for 1975 L-Jet, looking for info
rick_cv
post Sep 18 2022, 10:01 AM
Trying to piece together an L-Jet fuel injection system with the parts I currently have. Missing the ECU and have a 6 pin AFM. Does anybody know what the correct ECU part number is for a 6 pin AFM? The early 1974 411 has part number 022906021F and the going rate is 1/3 the price of a 1975 914 unit, part number 022906021G. A 1975 bus ECU typical part number is 022906021H. These are all indicated for manual trans but not sure which AFM they work with. Thanks
rick_cv
post Sep 18 2022, 05:05 PM
Thanks for the info. I will take a look and see what part number my AFM is and try to cross reference it on these charts. It is confusing with 6 pin/7 pin difference and what ECU works. I believe the wiring harness (which I also have) varies too.
wonkipop
post Sep 18 2022, 06:04 PM
QUOTE(rick_cv @ Sep 18 2022, 05:05 PM) *
the 914 stuff is easy.
its listed in the parts catalogue for the 914s.
for 74 and 75. the way they do it is note it as after a certain EC engine number.
its been extracted out in that thread i linked to to make it a little easier.
the interesting question you ask is would the 74 412 ECU be compatible.
i don't know to be 100%.
its a worthwhile question but hard to get to the bottom of.
there were only 412s with L jet for 1974 MY so that would be the only one to look into.
74 ECU compatibility. it would be a six pin like the 914s.
in 75 the 1.8 engine is only going in the 914s, the 412 is over at that point.
and as mr. b notes - different AFM, different ECU and has 7 pin connector harness.
that might be the only real difference, the 7 pin harness.
the way the engine runs as mapped by the ECU is probably the same.
49 states 75 1.8s were basically californian 74s.
they did change the decel valve. that was different from 74 to 75.
but i do not believe they "essentially" changed anything else.
- Lo-Fi Version Time is now: 22nd December 2024 - 08:20 PM
