WTB partial 75 2.0 wiring harness / ignition, Need uncut wires for ignition etc. |
Graydingo |
Sep 16 2022, 06:37 AM
Member Group: Members Posts: 57 Joined: 12-August 22 From: Las Vegas Member No.: 26,768 Region Association: Southwest Region |
Previous owner went nuts in my 75 2.0 ignition harness cutting all the wires that plug into the key/ignition. So I'm looking for the 6 wires complete, full length coming out of the black plastic plug that plugs into the back of the column ignition switch.
I also need this yellow with red stripe wire complete that seems to run the length of the harness. I'd like soft pliable wires and will consider full used OEM harnesses for the right price. Thanks in advance! Duane |
Graydingo |
Sep 19 2022, 11:09 AM
Everyone, thank you so much! I've got a full 76 harness coming thanks to the board.
914sixer: Yes! The yellow wire was completely taken out of the ignition plug! I inspected the harness over the weekend from the interior fuse panel back and wow, it's much worse than I thought. I need way more than the ignition sadly. Multiple exposed wires, and two areas where a hot fused with a ground and fully melted both wires. There are probably 30 cut wires in this thing. Having said that I extracted the full 75 EGR and CAT harness from the counter, to the dash lights all the way back to the pin connector in the engine bay. If for some reason some one needs this harness to go back to EGR and CAT setup. The EGR counter and the Cat are actually connected in the same harness. Again, thank you to Sixer and Mark for pulling stuff out and posting a pic, you guys rock. |
Lo-Fi Version | Time is now: 22nd January 2025 - 02:40 PM |
