Steering wheel, Ground wire |
NARP74 |
Sep 22 2022, 09:08 AM
Senior Member Group: Members Posts: 1,175 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
I assume there is supposed to be a ground wire in the steering wheel column and power for the horn. Mine does not have the ground wire. I suspect it was a hastily reassembled job. I have a temp solution but what is the way they used to be from the factory? How much disassembly and fishing do I have to do to get it in there? I have a Momo steering wheel, not stock.
mgphoto |
Sep 22 2022, 11:25 AM
"If there is a mistake it will find me" Group: Members Posts: 1,363 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
I assume there is supposed to be a ground wire in the steering wheel column and power for the horn. Mine does not have the ground wire. I suspect it was a hastily reassembled job. I have a temp solution but what is the way they used to be from the factory? How much disassembly and fishing do I have to do to get it in there? I have a Momo steering wheel, not stock. The Momo wheel complicates things, early factory has a plunger that grounds the horn making a circuit, later version has a grounding ring that connects to the batwing with a small connector. My first 914 had an aftermarket steering wheel the horn was activated by a button on the dash. Not my solution. |
NARP74 |
Sep 22 2022, 01:00 PM
I assume there is supposed to be a ground wire in the steering wheel column and power for the horn. Mine does not have the ground wire. I suspect it was a hastily reassembled job. I have a temp solution but what is the way they used to be from the factory? How much disassembly and fishing do I have to do to get it in there? I have a Momo steering wheel, not stock. The Momo wheel complicates things, early factory has a plunger that grounds the horn making a circuit, later version has a grounding ring that connects to the batwing with a small connector. My first 914 had an aftermarket steering wheel the horn was activated by a button on the dash. Not my solution. That explains some things, thanks. |
Lo-Fi Version | Time is now: 26th September 2024 - 05:30 PM |
