Front Mounted Oil Cooler ..., what has worked for you? |
SirAndy |
Jan 15 2005, 10:37 PM
Resident German Group: Admin Posts: 41,694 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
i know we've been through this before, but ...
i'm now actively looking to assemble a front mounted oil-cooler. what has worked for you? brand? size? thermostat? line-size? right now, the engine is a warmed up 2056. the car will definately see some track-time during '05. also, keep in mind that i still plan on putting in a /6 one of these days, either 3.2 or 3.6. so, i would like to (at least) have the lines the proper size for that already. what kind of thermostat do you guys run? what brand cooler? what size oil-lines? what route? ( i would prefer to retain heat, if possible) don't want to do the under the rocker panel thing. so i think i'm kinda stuck routing through the cabin. any objections? how about higher volume oil-pumps? pickup points? return? i have a oil-filter location sandwich adapter. good or bad? whatch'ya'all think? (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) Andy |
Maltese Falcon |
Jan 16 2005, 12:19 AM
Advanced Member Group: Members Posts: 4,715 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
Trekkor, there are several round bulkhead-pass-thrus in the rocker area, perfect for the tube (which will save $$$ over AN braided) in that area. Grainger, McMaster or other industrial surplus carries nylon covered brackets , handy for hold downs in fab'ing up the twists and turns. Keep the hard lines from vibrating--which will cause leaks in the silver soldered joints (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif)
I'm desperate for a canyon run...my six has been up for a month--finishing up new prototype rear puck/disc ebrakes. Oh well , most of our canyons are not driveable now anyhow ! Marty |
Lo-Fi Version | Time is now: 20th June 2024 - 05:59 AM |
