Front Mounted Oil Cooler ..., what has worked for you? |
SirAndy |
Jan 15 2005, 10:37 PM
Resident German Group: Admin Posts: 41,806 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
i know we've been through this before, but ...
i'm now actively looking to assemble a front mounted oil-cooler. what has worked for you? brand? size? thermostat? line-size? right now, the engine is a warmed up 2056. the car will definately see some track-time during '05. also, keep in mind that i still plan on putting in a /6 one of these days, either 3.2 or 3.6. so, i would like to (at least) have the lines the proper size for that already. what kind of thermostat do you guys run? what brand cooler? what size oil-lines? what route? ( i would prefer to retain heat, if possible) don't want to do the under the rocker panel thing. so i think i'm kinda stuck routing through the cabin. any objections? how about higher volume oil-pumps? pickup points? return? i have a oil-filter location sandwich adapter. good or bad? whatch'ya'all think? (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) Andy |
Steve |
Jan 16 2005, 09:50 AM
914 Guru Group: Members Posts: 5,682 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
How do you clean behind them?? I think your only option for running the lines will be through the passenger compartment or giving up one of your heater tubes either on the drivers side or the passenger side. |
Lo-Fi Version | Time is now: 21st September 2024 - 06:47 PM |
